Archive
Hi there,
I’m not able to launch Sticky notes - issue with accessing the file. It worked just fine before the updates that I made on my Windows 7 and I had to reinstall because the error appeared. Can anyone help me to fix this ? Why I have this error ?
Thanks !
Not able to launch Sticky Notes. Issue with accessing the file (Quit)
Read more
Today this message appeared on my desktop about Profile storage space. I don’t know how to check how much space I have left or how much space is busy. Can anyone help me to check and if is possible please tell me more about this.
Thanks !
You’ve exceeded your Windows Roaming Profile Quota. Run: ECN HELP -> Clean My Profile. If this doesn’t reduce your profile enough, see KB article “Windows Roaming Profile” @
https://engineering.purdue.edu/ECN.
OK
Read more
Hi there,
After I made an update to my VM every time I want to run Virtual Box this error warn me about action. I don’t know what it really means so please can someone help me to solve this and why I have this, can it be prevented in the future ? Did I make some wrong settings ?
Regards !
VirtualBox – Error
Failed to open the CDDVD image C:
Usersmjonesdownloadsubuntu-10.10-server-i386.iso.
Could not get the storage format of the medium ‘C:UsersmjonesDownloadsubuntu10.10-server-i386.sio’ (VERR_NOT_SUPPORTED).
Details
Result Code: VBOX_E_IPRT_ERROR (0x80BB0005)
Component: Medium
Inferface: IMedium
{9edda847-1279-4b0a-9af7-9d6625ccc18}
OK
Read more
I am trying to play BF3 using two GTX 580 cards with surround gaming on three 1920x1200 monitors. I have the 285.62 Nvidia driver. When the game loads, my monitors go blank. Then they go to sleep, then they start alternating waking up with a blank screen and going back to sleep. After about a minute or two all my monitors come back on and I get a DirectX error message. I will post a pic of it. I have uninstalled and reinstalled the graphics driver 3 times. I can run other games on all three monitors with no...
Read more
Hi experts,
When I want to configure a new client with Microsoft Outlook this unexpected error appears and I have to make the settings again. The result is this unexpected error, again and again. Is working just fine with my other 2 account to connect and sending e-mails, but I cannot create and configure another one. Anyone knows why ? What might be the problem and how can I solve it please ?
Thank you !
Microsoft Outlook facing unexpected error
Read more
Hi there,
I recently upgraded from Linux Mint 15 to Ubuntu 13.10. I have a PC with a shared folder created using Windows Groups. But now that I upgraded to Ubuntu 13.10 I have this Mount Error. Can anyone help me to fix this ? Why I have this ?
Thanks !
Mount Error
Can’t mount devide/org/freedesktop/Hal/devices/volume_uuid_8be6636c_648b_4a54_ba8c_70e03f2064cb/media/part1
Org.freedesktop.Hal.Device.Volume.PermissionDenied
Refusing to mount device/dev/sda1 for uid=1000
Read more
Hi there,
I am trying to update my application using application loader. When I submit the archive file, I got this error. I have deleted the icons from my project and tried again, but the error exists. Can anyone help me to fix this error ? Why my iPod have some errors ?
Thank you !
Adding application
Software: /Users/admin/Desktop/Archieve.zip
Icon specified in the info.plist not found under the top level app wrapper: icon 57.png
Icon specified in the info.plist not found under the top level app wrapper: icon 114.png
Icon specified in the info.plist not found under the top level app...
Read more
I have been trying to load an application to my BlackBerry 9000 since last week and I have this error "This application is not compatible with your device and cannot be loaded". I don’t know how to fix this and why I have it. I think the problem might be caused by the update I’ve made to my Windows7. Can anyone help me please to fix this error ?
Thank you !
Error
This application is not compatible with your device and cannot be loaded.
Read more
I am facing Update Error Code 800F0092 on my Windows 8.1 64-bit PC. I can't continue with the KB2919355 update as it always fails. When running the update, it will stop in the middle of the update and there’s nothing more. The update will stop in the middle of the process and then the update error code 800F0092 will appear. How can I fix this?
Read more
Hi experts,
This error appears during the extraction of data from an archive. I tried to extract the archive with WinRAR and the same error appears. The archive is not broken because my friend extracted the data without a problem. Does anyone have any idea on how can I extract the data without this error ? Why my programs don’t work?
Thank you !
WinZip Self-Extractor
Can’t create output file: dksports-datafootballSETUP.LST
OK
Read more
