Archive
Hello all,
When I try to open a document in Word web app, I got this weird error message. Recently I update all my application in the computer and it all went perfectly good. It does not throw any error while installation and upgrade. Why I am not able to view the document in Word web App? Please help to solve this. Thanks.
Microsoft Word web app
Word web app cannot open this document for viewing due to an unexpected error. To view this document, open it in Microsoft Word.
Error Id: 4155257e-d58d-4b8a-edfdc01c52de, 20120326151604
Read more
Hi Expert friends,
I am stuck with an error message not able to proceed further from this point. I am beginner or fresher in SharePoint having hard time with this error message. The error says ‘An unexpected error has occurred’. How do I fix this error? Please help me rectify this problem. Thanks.
Error
An expected error has occurred.
Troubleshoot issue with Microsoft SharePoint Function.
Correlation ID: 4775109-3879-e0e4-780e-57292b7dc3ad
Date and Time: 4/1/2013    11:14:07 AM
Read more
Experts I am facing a problem with SharePoint when I try to edit list form for my SharePoint site from InfoPath I ended up with an error message. I got the software from the authorized website; I do not understand where I did the mistake. Please help me correct the mistake. Thanks a lot.
Microsoft InfoPath
This feature requires SharePoint server 2010 or greater with InfoPath Services enabled.
Read more
Hi there,
Using Vault PRO 2014 SP1 I have this error when I want to check any random file in AutoCAD Architecture 2014. I tried everything to fix, I even uninstalled and made a new fresh install of AutoCAD 2014 and is not working. Any solution ? What could be the problem ?
Thank you !
Vault Add-in Error
An error occurred during a vaulting operation.
OK
Read more
Is not the first time when I want to save .dwg file. It doesn’t matter that is a small file or a big one the error is the same. Can anyone help me to fix this ? What could be the problem ?
Thank you experts !
AutoCAD Message
Unable to save to drawing C:UserslgorDocumentslgorDesignKazenny
PereulokKazenny_new.dwg.
Drawing saved to C:UserslgorDocumentsIgorDesignKazennypreuloksav81EB.tmp
OK
Read more
While working in SharePoint project when I try to connect to a light switch I got this error message. This means the installation was not good; do I need to reinstall it again? I am just a beginner please help me to get rid of this error. Your help is great. Thanks.
SharePoint Connection Error
Cannot connect to the SharePoint
http://--------sharepoint .com/developersite/. Make sure that the Site URL is valid and that the current user has the necessary permissions to access the site.
Additional information:
‘The specified command ID
Microsoft.VisualStudio.SharePoint.Commands.ValidateSite’ does not match any available SharePoint remote commands
Parameter name...
Read more
Hi Tech people,
I got this error message when I try to launch the Microsoft Visual Studio in the computer. The error says that the ‘component ‘MSCOMCTL.OCX’ or one of its dependencies not correctly registered: a file is missing or invalid’. How do I fix the missing file? Please help. Thanks.
Launcher
Component ‘MSCOMCTL.OCX’ or one of its dependencies not correctly registered: a file is missing or invalid
Read more
Hi Pro Experts,
Something weird happened to my computer when I try to work with Registry server. I get several times the error message popup within seconds and it disappears. I tried very hard to get a screen shot. Please help me get rid of this error message. Your help is great. Thanks.
RegSVr32
LoadLibrary(..............................)failed. The specified module could not be found.
Read more
Hello there,
I am not a technical person finding very hard to solve this problem. The problem is when I click on Control Panel to change my account information I ended up with an error message. For your information, this is my personal computer. Please do check my error message and help me to solve the problem.
::{26EE0668-A00A-44D7-9371-BEB064C986839::{60632754-C523-4862-845C-4172DA012619}
No such interface supported
Read more
Hi there,
In windows operating system whenever I try to register a dll I get this weird error message. I have attached the similar error message from different dll file. They all failed to load the dllregisterserve, in what way I can be successful. Please guide me. Thanks a lot.
The module “Oleaut32.dll” was loaded but the call to DllRegistereServer failed with error code 0x80070005.
The module “Shdocvw.dll” was loaded but the entry-point DllRegisterServer was not found.
Make-sure that “Shdocvw.dll” is a valid DLL or OCX file and then try again.
Read more
