Archive
Hello friends,
The installation and setup went pretty well and good. However, the problem triggered while I start to work with it. It says that it failed to create mapping. I am not aware of where I went wrong. So please help me to find the root cause of this error message. Your help is appreciated. Thanks a lot.
Microsoft Visual Studio
Failed to create Mapping
Access to the path ‘C:ProgramDataMicrosoft Team Foundation Local
Workspace9bf12291-6298-4274-bb09-96727b2s1f1PEI:f7e7f
Eef-b984-486b-a54cba0335a2properies.tf1’ is denied.
Read moreHi friends,
When I am with the newly installed Microsoft Visual Studio, I ended up with an error message. I got this error message when I am trying to connect with the access database. The error states that “The ‘Microsoft.ACE.OLEDB.12.0′ provider is not registered on the local machine” Does anyone know how to fix this problem? Please help. Thanks.
The Microsoft.ACE.OLEDB.12.0’ provider is not registered on the local machine.
Read moreHello there,
I am new to Microsoft Access I got this error message and I am stuck here. I download and installation was good without any issues. When I start to work, I am getting lot of errors. Please help. I have attached the error message please do check the attachment. Your help is great.
Microsoft Office Access
Invalid bracketing of name ‘SELECT [900-01_NUMERO’.
Every time I want to ArcGIS Explorer Online to see some maps I have this error. I even tried to use ArcGIS.com map viewer and sometimes it works and sometimes my PC is crashing. Can anyone help me please to fix this ? What could be the problem ?
Thanks !
Unsupported webmap version number (1.9.1)
Read moreHi there,
I made a full install of 3Ds Max and installed some required plug-ins and when I tried to open the program this error appeared and now I have this every time I open the program. I don’t know what plug-in should I uninstall so is there anyone who can help me please with this ?
Thanks !
Plug-in Assembly Load Error
The assembly C:Program FilesAutodesk3ds Max Design2014binassembliesAutodesk.Max.Wrappers.dll encountered an error while loading.
It is possible that this error put the application in a bad state. The application will continue to run, but we recommend quitting the application, removing...
Read moreHello experts,
I want to install Autodesk Revit 2013 and I have this error message and I cannot skip or what is the solution for this error. Is there an expert online that can help me please ? Why I have this error ? What is causing this ?
Thank you !
Autodesk Revit 2013
Error – cannot be ignored
Method ‘GetVersion’ in type ‘REX.Extension1.FoundationApplication’ from assembly ‘12d Model To Revit 2013, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null does not have an implementation.
Show More Info Expand>>
OK Cancel
Read moreHi there,
I got this weird error message when I try to rename the file or folder in the computer. The error says that it cannot rename “picture” because a file or folder with that name already exists. Specify a different name. I am sure I do not have a file in that name. What might be the other issues in renaming a file? Help please. Thanks.
File and Folder Rename
Can’t rename “Pictures” because a file or folder with that name already exists.
Read moreHello,
While working with DTS Import/Export to copy data from one the data source I ended up with an error message. When I select the Microsoft OLE DB Provider for SQL server, I got this error message pop up. I stuck here not able to move forward from this step. Please guide me. Thanks a lot.
DTS Import/Export Wizard Error
Error Source: Microsoft OLE DB Provider for SQL Server.
Error Description: [DBNETLTB][ConnectionOpen (Connect()).]SQL Server does not exist or access denied.
Context: Error during initialization of the provider.
Read moreHello DBA’s,
When I try to establish the connection Microsoft SQL, I ended up with an error message. It says the server does not exist or access denied. However, to my knowledge server exist and I have an authority to access the server. How do I establish the connection now? Do I need to check the settings? How do I check where I went wrong? Please help. Thanks.
Microsoft SQL Server Login
Connection failed:
SQL State: ‘01000’
SQL Server Error: 5
[Microsoft][ODBC SQL Server Driver][DBNETLIB]ConnectionOpen
(Connect()).
Connection failed:
SQL State: ‘08001’
SQL Server Error: 17
[Microsoft][ODBC SQL Server Driver][DBNETLIB] SQL Server does not exist...
Read moreHi,
While working in project in Microsoft Access I got this weird error message. I have been doing action for quite long and never experienced this before. I do not understand what to do now to solve this error. The error says it ‘could not find the specified .mdb’. When I try to initiate the procedure, I got this error message pop up in Microsoft Access. Please help. Thanks.
Microsoft Access
Could not find file C:UsersAlicia.Alicia-PCDesktopClientFiletbITechnicians.mdb.
