Archive
The C1100 CS24-TY server will no longer POST after updating the BIOS. It will turn on and I can hear the fans spinning fast but BMC is not available and it does not post. The light on the front is amber. I've read about using the BIOS recovery mode, but it does not seem to work. Have you ever experienced something like this before? Is there anything else I can try to fix it?
Read moreI have an Apple TV 2 and I want to remap the remote buttons in XBMC. Is this actually possible? How can I make the up and down buttons to skip chapters and not the volume keys? Can I use Cyberduck to make an SFTP connection to my TV? Please help.
Read moreI have been using my Samsung Galaxy S4 for a year now. It works fine and it has great features. The problem is, this is a 16GB model of S4, but it is showing only 8.5GB of free memory space. I don't have much files on my phone except for the operating system installed on it and some preloaded apps. Since I cannot remove the OS and some preloaded apps, are there any option where I can increase the memory of my phone?
Read moreWe have an HP 5500 switch. The MAC clients fail when DHCP-snooping has been enabled on the E5500-G-EI, although the PC PXE clients are able to boot successfully. What is the possible solution to modify the ACL to check for fragmented packets? What would be the maximum packet size to be configured on the PXE server to mitigate fragmentation?
Read moreHi. My LG Nexus 5 Smartphone is facing some issues on its camera. Nowadays, Smartphones are known to have great features in all aspects. But my phone's camera is showing poor resolution and my pictures are usually blurred. It even has a slow auto-focus and shutter lag. I want to know if this is a normal issue with Nexus 5 or if not, what can I do to resolve this?
Read moreHi. I am facing a minor but frequent issues on my Samsung Galaxy Duos. When replying to my emails, the cursor will always go to the end of the message. No matter how many times I put it back to the start of the message, it will return to the end of it. How can I fix this issue permanently? Please help me with this problem. Regards.
Read more
Hi. I am very fond of using my LG Nexus 5. With all the great features, I can say that, it is probably the best for me. Everything is present in this phone. However, it is pack with 2300mAh battery which drains easily compared to other top-of-the-line Smartphone. I want to know if I can purchase or if there's any other alternative method where I can extend the battery life of my phone. Can anyone help me? Regards.
Read moreHi. I am using a Nokia Lumia 800 and I am having some issues on my Internet Connection. I don't have issues on connecting to Wi-Fi, but when going through my browser to my Network settings to connect, it will work fine for few days and then later, my browser won't display webpages correctly. I checked on the settings and there seems to be no issues. I saw a 3G sign and that I am also connected to the Internet. However, I am unable to browse any web pages. I want to know if this is an issue with...
Read moreHi. I am using my Samsung Galaxy S4 for the last few months and it is showing some major issues since it keeps on rebooting by itself. It will usually restart from time to time. No matter what I am doing, it will restart itself. I don't know how to resolve this and I am in need of great help. Thanks and regards.
Read moreHi! I'm using my Samsung Galaxy Duos for quite a long time now. And since then, I am getting this issue. The phone log image has a number 3 on it, indicating that I have 3 missed calls. And once I open the log file, my phone will suddenly shuts down. And I am stuck with the same issue even if I received another missed calls. What can I do now? Help please. Many thanks.
Read more
