Archive
I am using Dell XPS laptop L401X, recently while checking my battery I realized that my laptop has a big SIM card slot, I have tried to use it, but can't do successfully, do you have any suggestions to use it, because I could not find anything helpful on Dell's Official website. Is this slot is really meant to use SIM card it Laptop or anything else?
Read more
I am using Dell laptop, recently my charger is acting awkwardly, it gets heated up very easily and then stops charging, but eventually it again starts charging the battery. I am using the original Adapter with correct Voltage Specifications as mentioned, but still having this issue. What could be the possible reason behind it? Please suggest any fix.
Read more
I am using ASUS Laptop. Recently my Laptop's battery has started acting strangely. Even though charger is well connected to Laptop, it doesn't charge. Even if battery is low, sometimes when I start Laptop, error message regarding battery occurs, but it goes away itself? Can you suggest any solution for it?
Read more
I am using Linux OS for my laptop. Before Linux, I was using Windows 7, and actually it was very easy in Windows to connect my Samsung Smart Curved TV with Laptop through HDMI port. But I can't do the same in Linux. No external display supported error occurs in Linux. Is there any easy way possible for that?
Read more
I am using a Dell Laptop and have recently upgraded my RAM from 2 to 4GB, is there any way possible that I can utilize the total capacity of these RAM's? Should I use virtual box, for different OS or with this high capacity, I don,t virtual box? One more thing, is there some way possible, through which I can actually use more than one OS without using virtual box?
Read more
I settled with the digital ocean for a virtual server and SoftEther for the VPN service. Once connected, I have an IP in New York but Google keeps redirecting me to their site in Hong Kong. If I get the VPN disconnected American site as usual. I do not know what happened. I use Mac OS X 10.9 and Firefox 26, if that matters.
Read more
I want to create an MSN Messenger client on the Web as Meebo for my users. I think ajaxim to use user interface and libpurple based. http://ajaxim.com/ http://old.ajaxim.com/ - demo here I want to learn though. The fastest way to get there, or is it an open source project that I can fit written ideas and alternative means are also popular.
Read more
I recently got a new nexus 5 and i have come across an issue. I am trying to connect my Nexus 5 to my Laptop via USB. Each time it detects the phone but the driver installation says Failed. So i would like to know that is there an issue with the handset or there is some other issue ?
Read more
I got my Note 4 today(Tmobile) and tried to enter my information on the phone website. It asks for IMEI and WIFI MAC address. After entering those, I get an error that IMEI and MAC address are invalid. Samsung support says the IMEI is valid. The MAC address is copied directly off the phone. Different browsers or machines make no difference. So i would like to know what kind of issue is this ?
Read more
I'll start by saying that I had my S4 Cat-A for about 6 months now. About halfway through April began to experience this problem. There was no animations between minimizing and opening apps. I fixed this by enabling developer options to find that "transition animation scale" had for some reason disabled itself. At first I didn't think much of it. But about two weeks later it disabled itself again. I then re-enabled it again thinking that if it was a persistent issue it wouldn't be the end of the world to keep sorting re- enabling this option. So would...
Read more
