Archive
I had lost my data and tried to recover data from different tools and fortunately, I retrieved the lost data back with a new error message. When I tried to open, any excel file I got the following error message. I have tried many solution to resolve this problem but still unsuccessful. I need your help to fix this issue as soon as possible. Thanks.
The file format or file extension is not valid. Verify that the file has not been corrupted and that the file extension matches the format of the...
Read more
Hi experts,
I tried to customize an installation of the 2007 Microsoft Office system using Office customization Tool. When I did this then I received the following error message. Suggest me the step by step solution to resolve this issue. Thanks.
Files necessary to run the Office Customization Tool were not found. Run Setup from the installation point of a qualifying product.
Read more
  Hi, I am having trouble using SQL 2008 R2 SSRS. When I try to access SSRC on SQL server 2008 R2 I receive an error message which I can’t resolve so I need your help to demolish this problem. Any help would be appreciated. Thanks.     SQL Server 2008 R2 Reporting survives Configure action Manger Unable to connect to the Report Server
Read more
Hi experts,
I have installed Dynamics AX 2012 and installed Excel 2010. Now I am trying to remove the following error message. I get this error when I click on the Connect Button in Dynamics AX tab. Help me to resolve this error immediately.
This operation is not supported for a relative URI.
Read more
I have installed Windows XP SP3 and using Office Home and Student 2007. When I open any Office program I receive the following error message every time. I tried to repair the setup but could not resolve this error. I don’t know how to find the solution to demolish this error. Any suggestion would be helpful.
The setup controller has encountered a problem during install, please review the log lilies for further information on the error.
Read more
Hi.
When tried to open another user's mailbox in Microsoft Office Outlook 2003 and then clicked Out of Office Assistant on the Tools menu, I received the following error message. How can I fix this issue? Help me to resolve this problem. Any help would be appreciated.
Microsoft office outlook
Your Auto Reply message Could not be displayed. The client operation failed.
Read more
I am trying to install 64 bit-version of Office on my machine with 32-bit but I receive the following setup error message. Can I install 64-bit Office on machine without any problem or I need to install 32-bit setup? I need your suggestion.
Setup Error
We can’t install the64-bit version of Office because we found the following 32-bid programs on your PC:
Microsoft Office Professional Plus 2010 Please uninstall all 32-bit...
Read more
Hey everyone,
I would like to install kiwi linux to a flash drive from windows but I have no idea how to do it. Can anyone list the steps for doing this? Thanks you in advance.
Read more
Hey,
I recently installed puresight content filter and wingate. The problem I am having is I can not seem to get puresight to block anything. Both of the licenses are correct. Any suggestions?
Read more
Hey,
I am having trouble repairing damaged sql server database. The error is "systemtable: object_id = 7 = sysallocunits". Is there a sql repair command or tool? Any help would be great, thanks in advance.
Read more
