Archive
The TweakUiPowertoySetup.exe installer is not working on my computer. Was this GetDirectoryDllW procedure added to kernel32.dll in the SP1? How can I fix it? Any idea would be greatly appreciated. Thanks in advance.
he procedure entry point GetDllDirectoryW could not be located in the dynamic link library KERNEL32.dll.
TweakUiPowertoySetup.exe – Entry Point Not Found
The procedure entry point GetDllDirectoryW could not be located in the dynamic link library KERNEL32.dll.
OK
Read more
I received an error message when I was trying to mail merge using Word 2010. When I attempted to create 2010 files using Excel 2007 files which were originally saved, the following error message appeared. Give me the solution to resolve this problem.
Thanks in advance.
Microsoft Word
Error has occurred: External table is not in the expected format.
Read more
I am using Windows 7 OS and from the last days I am receiving a Windows COM error. Is this problem with the server or anything else? Tell me the reason of this error. How to solve? The error image is attached below so suggest me the proper way to resolve this problem.
ERROR
COM Error
Action: Looking up next segment
COM Error
Call to Felix.WordInterface on automation server failed.
COM error code: 0*8004003
Error: Invalid pointer
Read more
I downloaded SiSoftware Sandra on my Vista Ultimate 64-bit Edition and the website were showing the fully supported with my machine. After downloading and installing the software when I tried to run it an error message appeared. Have any idea to fix it?
Could not initialize database! Check database file, database server, or MDAC.
SiSoftware Sandra
The server has reported the following area:
MDAC.
OK Help
Read more
When I added an Office 2010 KMS Key on a Windows 2008 R2 KMS Server then an error occurred, using Microsoft Office 2010 KMS Host License Pack. I tried hard to solve this problem but couldn’t. Any help would be appreciated.
Thanks in advance.
An error occurred: 0x80072F8F
To display the error text, run the following:
Slui.exe 0x2a 0x80072F8F
Read more
I wanted to create a backup image of the hard drive of my Desktop in the same way but when I try to do it I get this error message. Anyone know what the issue might be? Any help would be appreciated. Thanks.
Error #1722 – “The RPC server is unavailable. (0×FFF0) code = FFFFFFFF800706BA Tag = 0×BD28FDBD64EDB821”.
Error
E00640068: Failed to create the scheduled task
Failed to create the scheduled task. Error #1722 – “The RPC server is
OK
Read more
Recently, I was trying to launch Absinthe app during the jailbreak process but I received an error message “Error establishing a database connection”. How can I fix this error? I would be really grateful to you if you suggest me step by step.
Read more
I have a trouble while downloading the Windows Store Apps. When I try to install the apps it gives me the following error message “app couldn’t be installed”. How to resolve this error? Any help would be appreciated.
Thanks in advance.
Something happened and this app couldn’t be installed. Please try again. Error code: 0x8024600e
Read more
I received an error message while loading Speccy64. The following error message shows the missing file. How can I fix it? I reinstalled the program but the same error displayed. Any help would be really appreciated. Thanks in advance.
The program can’t start because MSVCR100.dll is missing from Your computer
Speccy64.exe – System Error
Your computer. Try reinstalling the program to fix this problem.
OK
Read more
Hello experts,
I was trying to update the Apex Launcher App from the Google Play Store but an error message appeared during the downloading this app. I restarted the Play Store to download this app but the same error message displayed. How can I solve this problem? Is this a problem with my Google account? I really need your suggestion to resolve this matter.
Error
Update for “Apex Launcher” could not be downloaded due to an error. (921)
Read more
