Archive
Hello experts,
I got an error message using the Open Broadcaster Software. The following error shows Entry Point Not Found. Have you any idea about this error? How can I fix it? Any help would be really appreciated. Thanks in advance.
Open Broadcaster softwarev0.472b: OBS.exe- Entry Point Not Found
The procedure entry point
?InitAudioData@AudioSource@@IAEX_NIIIKO@Z could not be located in the dynamic link library OBSApi.dll.
Read moreHi,
I am getting Windows error in these days, which says “The exception illegal instruction”. The error image attached below so please tell me the reason of this error. How can I fix it? Any help would be really appreciated. Thanks.
Ffmp_avanti.exe – Application Error
The exception Illegal Instruction
An attempt was made to execute an illegal instruction.
(0×c000001d) occurred in the application at location 0×0080a39d.
Click on OK to terminate the program
Click on CANCEL to debug the program
OK Cancel
Read moreHello,
When I try to load MPEG2video, an error message appears. I checked all the settings but they are default as it is. How can I remove this error? Can you provide me the solution? I really need your help. Thanks.
Error Setting video
ffmpegsource factory: FFmpegsource video provider: Failed to index: Can’t create parser
avisynth factory: AviSynth error: FFVideoSource: Can’t create parser
OK
Read moreHi experts,
I was trying to open a FLAC file in Ubuntu 11.10, sonic visualizer fails to recognize the file using librdf then I received the following error message. Can you provide me the best solution to resolve this issue? I would be really grateful to you.
Failed to open file
Audio required
Unable to load layer data from
“/media/vault/docs/phd/data/rabbits/cough/audio/r32_2012-03-23_16:06_after-
Air-exposure-citric-acid_0+8M.flac” without and audio file.
Please load at least one audio file before importing annotations.
OK
Read moreHello,
When I install MAGIXMusic Maker 2013 Premium I get the following error message. What to do to fix it? Any Idea would be really appreciated. Thanks in advance.
MAGIX Music Maker
The program could not be started. It’s possible that the
Installation folder is damaged.
Reinstalling the program could remedy the problem.
If the error occurs again, please contact support.
Error code: - 6
OK
Read moreHi,
I am having trouble and found Error ActiveX 429 when trying to integrate BillQuick and QuickBooks. Any suggestion would be really helpful for me. I would be really grateful to you.
Warning
Error #: 429 (1AD) –
ActiveX component can’t create object has occurred in the following
Procedure. StartQBsession. Please contact Technical Support for
assistance.
OK
Read moreHello,
This message occurs when I open the Convert EDI POs to Sales Orders screen. Can you provide me the solution? Any help would be really appreciated. Thanks in advance.
System Message 15823
Error reading Transaction Log Directory. Process aborting.
OK
Read moreHello,
Adempiere
When I tried to post a material receipt document, It gave me a posting error message like " Posting error [DR not created etc... " (the exact error message has been attached).
But when I use another dummy database, it’s got posted without any problem. What will be the reason, anybody have any idea.
Thanks & Regards
Material Receipt 10002MRV ADF-Admin@ADF SAUDI.RIYADH [Beta03-Erp002{beta…
Posting Error
Posting Error (DR not created: DocLine-[1007490,Op. Balance – Stock Spare Parts, M_Product_ID=1099478, Qty=2,Amt=0]) – Doc_InOut (MMR –
DocumentNo=10002MRV, DataeAcct=2010-02-28,...
Read moreHello,
Teradata DBS CRASHED OR SESSIONS RESET shows this error. What I do to fix it? Can you provide me solution to resolve this error? I am waiting for your help. Thanks.
Teradata SQL Assistant
0: WSA HostUnreach: The Teradata server can’t currently be reached
Over this network
OK
Read moreHello,
I am trying to connect the Informix database but getting the following error message. Please help me out to resolve this issue. Any help would be really appreciated. Thanks.
Informix ODBC Error Message:
The selected locale/codeset will result in performance degradation. For optimum
performance …
OK
Read more
