Archive
I installed SI on my system but when I attempted to run it, I got the following error message. Is this a location problem or something else? Where should be located SI? I would be really appreciated your help. Bundle of thanks.
Service Information installation directory not detected
Setup
Service Information installation directory not detected, click OK to exit.
OK
Read more
I have put the Eve data folder in my documents and have put the two dll's in vst folder .
I use Synapse Orion as my DAW and along with Wuzikstation , Eve shows in the insert list .
When I launch Eve I can see all the presets in browser but if I select any a white strip appears saying presets can't be found . How can I remove the following error? Can anybody here help ? I'm using windows xp home edition and Wuzikstation works fine . Thanks in advance
This plugin has no dispatcher or is otherwise buggy. Read more
Every time I create a new file and press Rosegarden saves it correctly. But the second time I press save the error message displayed on the picture appears, the original file is deleted from the folder where it was saved and a temporary file remains there. There is happening something wrong and very irritating. Have any idea? Thanks in advance.
Error was : Failed to rename the temporary output file
Rosegarden
Could not save document at
C:/Users/Fernando/Documents/Studio/rosegarden/-.org
'C:/Users/Fernando/Documents/Studio/rosegarden/-.rg..gq3676' to desired
Output file 'C:/Users/Fernando/Documents/Studio/rosegarden/-.rg'
OK
Read more
Today, when I tried to open MuseScore I got an error message saying it has stopped working. I installed the new version but still sowed the same error message. I really need your help to resolve this issue. Any help would be appreciated.
Failed. Playback will be disabled.
MuseScore: Load SoundFont
Loading SoundFont
“C:/Program Files (×86)/MuseScore//sound/TimGM6mb.sf2”
Go to Display > Synthesizer
And check that the file location is correct
OK
Read more
I am getting this following error message. Anyone please help me to solve this issue.
Thanks in Advance
The stream is not a PCAP file. Magic number is A0D0D0A Or A0D0D0A but should be A1B2C3D4.
Error opening pcap file: The stream is not a PCAP file. Magic number is A0D0D0A
OK
Read more
OpenBroadcaster keep getting this error whenever I try to start OBS Aero switches off, then the error occurs and after I close the error box Aero switches back on but OBS doesn't start. Everything worked yesterday.
I didn't change or install anything in-between. The '5' in the error is not always a 5. It varies.
Sometimes it's a 'u' or something else.
Sometimes even missing all together.
Help would be appreciated.
Error parsing X file ‘</ 5’
Fehler
OK
Read more
I have installed Backup Exec DLOprior in 2012 and migrated to Symantec DLO7.0 but Symantec DLO(Desktop and Laptop Option) 7.0 were not generated. The following error message appeared. Is this any way to resolve this issue? Any help would be appreciated. Bundle of thanks.
check that the report file 'DLOnobackups_en.rdl' is correctly installed. (0x8000FFFF)
"An error occurred while running the report 'No Backups'. Please check that the report file 'DLOnobackups_en.rdl' is correctly installed. (0x8000FFFF)"
Read more
I got an error message “Csound Command ERROR”.
I have updated the sound driver but still shows the same argument.
I really need your help to fix this issue.
Can you provide me solution to fix it?
I would be grateful to you.
Csou Csound error!
Csou
Csound error!
Csound Command ERROR: insufficient arguments
OK
Read more
I chose to use the NUnit Framework. I then tried an example found on the web and after the project was built, I loaded NUnit GUI and opened the unit test assembly, but to my surprise, the NUnit GUI was giving me Error message. It was telling me that the Test load failed with detailed error: SystemApplicationException: Unable to find test in the assembly. Help me! Thanks.
Unable to find test in assembly For further information, use the Exception Details menu item.
NUnit
Test load failed!
System.ApplicationException: Unable to find test in assembly
For further information, use the Exception Details menu...
Read more
When I open v. .0 scores in MS 1.0 via the desktop (double-click on the icon) or clicking on a link in the forums I get a dialog as seen below. Any help to resolve this error would be appreciated. Thanks.
Muse Score Reading file <C:UserschepersDesktopsrtytwr.mscz> failed: Result too large
Muse Score
OK Quit
Read more
