Archive
I am currently using Windows XP SP3 and receive an error message when try to start a service.
The service suddenly stops and an error comes up.
I am unable to solve this problem and don’t know about this error.
Why did come this error?
What could be the reason? Any suggestion would be really appreciated.
Error: Starting service: 1508: oh dear
Read more
I am getting an unspecified error when try to update a software using Nokia N95 through Nokia Maps Updater. The following error shows “The “NI-488.2.2.8” installation has failed with the following error [3]”. Can I get the proper resolution to solve this problem immediately? I will be very grateful to you for any kind of assistance.
Error: cannot get enough information about the phone [3] Unspecified error (1).
Read more
Today, I was attempting to install the National Instruments driver but an error message displayed during the installation saying “The “NI-488.2.2.8” installation has failed with the following error”. Is this really a problem with Windows installer? I have tried to reinstall this driver but could not find any improvement. I need help. Any help would be greatly appreciated.
Thanks in advance.
The “NI-488.2.2.8” installation has failed with the following error: There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or...
Read more
Recently, I was trying to uninstall the National Instruments Software but an error 1601 occurred during the uninstallation. I tried multiple times to uninstall this program but not successful. What could be the cause? Can I get the resolution to fix it immediately? I am using Windows Operating system so instruct me properly.
Thanks for help.
Error 1601 occurred. Would like to continue this operation?
Read more
I was attempting to upgrade Edge Router System but the System Upgrade Failed due to some error message. What could be the cause for this error? I need your assistance to resolve this issue. Provide solution step by step so that I may fix this.
Thanks in advance.
System Upgrade Failed There was an error upgrading the system.
Read more
An error message encountered when upgrading to Backup Exec 2010 R3. How can I fix the following error message so that I may install this program properly? I have reinstalled this application but the same error message appeared. Help me to resolve this immediately.
Thanks in advance.
Fatal error:error 1406.Could not write value AdammLocal to keysoftwaresymantecbackup execServer. Verify that you have sufficient access to that key, or contact your support personnel.
Read more
I attempted to install a big Logitech Alert update (~150M) and it took a long time and I left it in aggressive mode but after that Windows update showed an error message to install some .NET framework now I can’t start Logitech Alert because of an error message occurred during startup. I want assistance to resolve this issue.
An unexpected error occurred during startup. Please contact technical support with this error.System.EntryPointNotFoundException: Unable to find an entry point named ‘IsUserAnAdmin’ in DLL ‘Shell32.dll’ at Wilife.Interop.Shell32.UsUserAnAdmin() at Wilife.Interop.UAC.IsElevated() at Wilife.Werks.G.WerksEventlog_Initialize() at Wilife.Werks.G,InitializeEventLog() at Wilife.Werks.CInitStart..Ctor() at Wlife.Werks.G..ctor()
Read more
Hi experts,
Last day, I was trying to install iTunes using Windows XP for my iPhone but an error message has encountered due to some security issues saying “Error getting file security”. I could not install this software properly now I need an expert’s advice to remove this issue immediately. Any suggestion would be helpful.
Thanks for any assistance.
Error getting file security: C:ProgramDataappleinstaller CacheApple Software Update 2.1.2.120GetlastError: 5
Read more
I am using Mac Operating System and last day I was trying to install Dragonframe but the installation failed due to some reason. The installer encountered an error that caused the installation to fail. Contact software manufacturer for instance. Now how can I remove this error? Any idea would be appreciated.
Thanks for help.
There were errors with the installation. You may want to try i
The installation failed The installer encountered an error that caused the installation to fail. Contact software manufacturer for assistance.
Read more
Recently, I was trying to update my BlackBerry Desktop Software by connecting to the PC but an error occurred during the updating my software. The error shows “A connection to the tablet could not be established. Please connect your tablet and try again”. An error encountered at the end of installation. What could be the cause? I have tried to reinstall this software but no improvement. Any help would be appreciated.
There was an error updating your software. A connection to the tablet could not be established. Please connect your tablet and try again.
Read more
