Archive
I am converting Mac OSX Lion.dmg file with MagicISO to ISO image. That file has downloaded.
So, it can be used on Virtual Box and can be played.
But when I am selecting the DMG file an error message returns with ‘cannot be able to find the file or the file is not an image file’.
I have confirmed in the website that MagicISO is the right program for this task.
If anybody knows how to do this, please let me know.
I will be thankful for all your help.
Read more
I am planning to install 64 bit Windows 7 ultimate in my” MACBOOK PRO 13” edition of APRIL 2010 through ‘boot camp’.  Some videos in ‘Youtube’ suggest for using Macbook’s driver CD as opposed to using Windows update. What you all suggest? How can I get windows drivers without any Macbook’s drivers? Windows update can be used or not? If anybody knows the solution to solving this problem, please help me. I will be thankful for all your help.
Read more
My laptop runs with Windows Vista operating system. I have executed the system recovery with the installation CD of Windows Vista by selecting recovery command prompt. In the command prompt I have entered SFC / SCANNOW, but it is not recognizing. Please tell me what is happening. I will thankful for all the help.
Read more
There was 5 GB free space in the hard disk. But suddenly it got full.
So, I have deleted 3 GB data. But on the next day, in the morning, it is showing the disk is full. I have removed 21 GB data but it’s again down to 20 GB.
So, I have checked with ‘Malware bytes’, but nothing found. I have also executed the disk cleanup.
Please help me recognize the problem.
Read more
I am getting an error message in Windows Server 2003 which says ‘svchost.exe application error. The instruction on Ox6F8917C2 which is referred to as Ox6F8917C2 is not clear. The memory cannot be read. Select ‘OK’ to exit and select ‘CANCEL’ for debugging the program.’  If anybody knows how to solve this problem, please let me know. Thanks in advance.
Read more
I am making an application through Adobe AIR with Adobe Flash CS5. It runs well but when trying to publish the program it gives me an error as posted below. The .exe file is stored or saved in my drive C.
I checked on it but when trying to publish it, I still got the same error.
Help me please.
Error
CreateWinProcess failed with error 2: The system cannot find the file specified.
Read more
Missing Windows hal.dll file.The missing or cannot find hal.dll, windowssystem32hal.dll, or winntsystem32hal.dll error message may be experienced on a Microsoft Windows 2000 or Microsoft Windows XP system when the boot.ini becomes corrupted or when a user is attempting to dual boot a computer.
Read more
Hi. I need help on MS Office Access TransferSpreadsheet Macro. I need to insert common data’s in the main menu or switchboard of a database. This is to get rid of inserting data’s one by one. I tried this step but I am getting an error as posted below:
Microsoft Office Access
Microsoft Office Access was unable to append all the data to the table.
The contents of fields in 0 record(s) were deleted, and 1 record(s) were lost due to key violations.
* If data was deleted, the data you pasted or imported doesn’t match the field...
Read more
I am really new as an admin with MS Exchange. So this may seem not to be a tough question. I have searched for help for this problem, but no answer is forthcoming. The MS Exchange 2008 Server is being used in the office and we created email forwarding group. When any email comes to this group, it will forward those mails to 3 persons and it is working properly. Those persons want the subject line starts with ‘MAIL:’ I don’t know how I can do it. But I am sure it can be done. Please guide me to...
Read more
I am getting “Application Launch Error” when running Real Software: Real Studio 2011 R1 on my Mac OS X 10.6.7. This error just pops up upon launching the application. What should I do with this? I need help. Thank you.
The application launch has timed out
OK
Read more
