Archive
Hi guys,
I am unable to start the Windows Media Player.
When I do so, I get an error message saying:
C00D11CD.
I don’t understand why I am facing this error and how to solve the problem.
Please help me with this issue and suggest to me the steps that I should do to solve this one.
Basically, the fact is that whenever I start launching the Windows Media Player, it then prompts me this error.
If anyone experienced the same error then please help me in this case.
Thanks in advance.
Read more
I have downloaded all 4 ZIP files for 11.1.1..3 Windows 32 bit version, but was unable to unzip file named "bi_windows_x86_111130_32_disk1_2of2.zip". When getting to last file:
../bishiphome/Disk2/stage/Components/oracle.bi.xdo/11.1.1.3.0/1/dataFiles/filegroup1.jar
It prompts the message:
CRC failed, file is corrupt
Does anyone have any idea where to get correct ZIP? Please help me and tell me what is wrong here?
Thanks in advance.
Read moreHi all.
I am facing a problem during opening a zip file. I got a message that states:
"Windows cannot open the folder. The compressed (zipped) is invalid.
I also found the message "error WZ54", file transfer error, and zip file is damaged.
How can I retrieve my data from this zip file? Need your help. Thank in advance.
Read moreHi community,
I am receiving this error:
Error code: 0x80070035, the network path was not found
While trying to connect to any other computer (running Windows 7 Ultimate) on my network. I owned another computer with Windows 7 Ultimate, and it does not suffer from this problem. Firewalls are unable to perform on all computers.
Pings are fine on all computers. Ping by name is possible.
While trying to connect via IP address, I receive this error:
Error Code: Error0x80004005 Unspecified error
So please help me with correct suggestions.
Read moreHello guys.
I found the following error code "80072efe" while trying to update Windows.
Virus and spyware scans run without a cure, while firewall is disabled and failed to update.
If anyone experienced this problem then please share how you overcame it.
Any suggestions from experts will be really appreciated.
Thanks in advance.
Read moreCould you please help me how to set up the SCCM (System Centre Configuration Manager) in Active Directory with Win 2003 Architecture and what are its prerequisites for Configuration of SCCM,
thanks in advance.
Read moreHi guys.
Apple is providing support for the Classic operating system in Mac OS 10.5. Those who install Mac OS 10.5 onto their computers and then attempt to run Classic applications will see the following error message:
Hello guys,
I recently downloaded and installed OSX 10.7. However, I failed to run Software Update and was flashed with the following alert:
'Software Update can't check for updates because of a network problem. The file “index-lion-snowleopard-leopard.merged-1.sucatalog” couldn’t be found on the server “swscan.apple.com”.
I repaired permissions, created new user accounts, but the issue still persists. The internet connection is steady. Software Update System Preference has no entries in the "Software Installed' tab.
Help needed. Please help me with a solution.
Thanks in advance.
Read moreHello experts,
My Picasa always displays "Error: 17 REJECTED_USER_LIMIT" while I'm trying to upload the photo to Picasa Web Album if the photo dimension less than 800px.
When I joined the Google+ network, photos less than 2048px cannot be uploaded. Please, help me with correct suggestions.
Thanks in advance.
Read moreHi guys.
Here are some date problems I have using Filemaker Pro.
1. I'm seeing an issue where it appears to leave out vacant records with a date field. If I use "=", I receive the error message, saying that is not a valid date format. What are the appropriate steps to leave out an empty date field?
2. I am trying to make a comparison on dates using another date field in order to purify records. I am practicing with a date variable > $$This Month and compared it against the date field "This Records Date". I found the same...
