Archive
I am having trouble with this .zip and .rar files and I do not know how to open them. I have recently had these .zip and .rar files and I will have to analysis on them for my work. So should some one know the solution please let me know. It is very important for me since it is related to my first assignment.
Dixon Chapman
Read moreHello,
I have been using kmp for a while now. I have suddenly faced which I have not encountered before.
The kmp browser is showing a code error, and I do not know why is this happening.
Should someone know how to solve this problem please let me know. I will be glad if someone quickly solve this problem for me.
Kenneth Feugo
No combination of filter scould be found to render the stream.
Error Num: 80040218
Binary Info:
Data:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00...
Read moreHello,
I have an assignment in Microsoft word, and I do not know how to write equation 2007. I need the information quickly about how to write equations. I have tried to figure it out by myself but could not do so.
Please someone help me over come this predicament quickly.
Christian Briggs
Read moreHi,
Whenever I try to set up ODI lineage package it ends up in the following error screen:
Is there a possible solution for this?
Thanks in advance.
Read moreHello,
I have a MMC card in my mobile and it was working properly till now. I used to store mobile files in pc using card reader. But recently my pc is unable to detect the MMC card but the card reader. Please someone kindly help me find the solution for this problem.
Thomas Maloy
Read moreHi everyone!
ODI answers always display the same error whenever I try to save an existing report to another location or in another file using the save as option and it contains only very few things which the original file had.
The error says cube definition invalid and displays the following screen.
Error:
Pivot Table
View Display Error
Cube Definition is invalid (Measure out of bounds)
Error Details
Error Codes: GOA4AK7Z
If anyone knows the solution please tell me, it would be much appreciated.
Read moreHello,
My Mozilla Firefox browser has slowed down after installing avast free anti-virus. This has caused me hamper in my job. I tried re-installing it did not seem to work. I have just installed the anti-virus and I do not think uninstalling it again would be a good idea. please someone tell me what to do. It will be better for me if the problem is solved quickly.
Frank Marlow
Read moreHello,
Please help me I am stuck in installing this upgrade on my computer.
It downloaded successfully but when I try to install, the following screen pops up.
I tried to monitor the update during installation using advanced monitoring options, but there was nothing I could get out of it.
Does anybody know what to do?
Error:
Installation Failure
Error Code: 0x80070643
Try to install the update again, or request help from one of the following resources.
For self-help options:
Frequently Asked Questions,
Find Solutions,
Windows Update Newsgroup.
For assisted support options:
Microsoft Online Assisted Support (no-cost for issues related to getting updates)
Read moreHello guys,
I need some simple explanation about PageRank penalty, what is PageRank penalty and how does it relate to SEO? SEO experts , please help me.
Thank you
Read moreHello,
I would be much thankful if you help me in installing the bamboo dock on the latest version of Mac OS X v 10.5 running on my G4 machine. I downloaded the driver software required for this from over the internet which installed without any problem but when I try to install the dock it gives me the “Installation Failed” error.
It suggests me to postflight script for this and I have no idea what should I do?
The Installation failed.
The installation failed. If you have installed Bamboo Dock before please make sure that it is properly removed from your Application...
Read more
