Archive
I have a flat screen monitor which I want to connect to my DVD player.
The problem is my monitor got only two ports.
One is a 15 pin port,and the other is a dual port.
Please suggest me which converter should I choose for solving this problem.
I will be grateful if you send the answer quickly.
Robbie Lucas
Read moreHello,
Recently I have purchased some I-tunes with my debit card. I checked the balance after that but it seemed to be unchanged. I do not what happened. Whether it will be taken later or it is a mistake. Will this cause me further trouble later? If so, then how to solve it? Kindly let me know about the solutions.
Jovan Clayton
Read moreHello,
I had some problems while browsing. There are some advertising that I face each time I browse some specific sites of my interest. I do not like the advertisements and find it real annoying.
Is there a way to block the advertising from a particular website?
If there is then please kindly inform me about it.
Clark Orcus
Read moreHello,
I had an old I-phone which was perfectly synchronizing with my old laptop. Recently I have to buy a new laptop since my old laptop was damaged and it was un-repairable. I have heard from different sources that should I connect it the new laptop with my old I-phone I will lose my I-phone data.
Is there a way to save the data and then sync it with the laptop PC.
Kindly help me on this problem.
Dixon Chapman
Read moreWhat is paging in Computer Architecture?
How it works?
And how important role this technique can play in computer architecture?
And what is its basic role in computer architecture?"
Read moreSo recently I constantly keep getting this annoying pop up error on my screen.
Check the screenshot !
ERROR
What to do ?
Read more
So when I finished installing Win XP SP3 I get this error saying "stop error code 0x0000000A (IRQL_NOT_LESS_OR_EQUAL)". So can anyone tell me what seems to be the problem? :/
Read moreMy Photoshop is suddenly being all weird as it can't seem to be able to save my files instead its giving error saying that the file is in use or left open. Only Photoshop is using the file! So I don't know what has happened or what to do ! HELP ?
Read moreI have Windows 7 operating system, and whenever I try to connect with PPPoE connection I face an error saying "Error 651 :
The modem (or other connected device) has reported an error".
What should I do?
Read moreWhenever I try to use MSM IM it can't seem to be able to connect instead it gives an error 0X8100030.
So what should I do to fix this problem ?
Read more
