Archive
I have created a scrolling news line using "marquee". When I hover mouse over scrolling text, the text is not stopping.
I want it stop when mouse is placed on scrolling line. What is the way to do it?
Read more
When I tried to install the iPPOTV, I got the following error message (see image below):
I need to solve this. Thanks a lot.
Error:
Assertion failed!
Program: C:Program FilesiPPOTVStarP2P.exe
File: .Player.cpp
Line: 16
Expression: m_hModel
For information on how your program can cause an assertion failure, see the Visual C++ documentation on asserts  (Press Retry to debug the application - JIT must be enabled.
Read more
Hello community.
During a project working under Linux, I tried to copy a large (>8GB) file over the network from the Linux machine to another one. At the end of the copy procedure (even on a gigabit network),
I found an error message that says there was a problem while copying the file. Clicking on the “Show more details” showed me this:
Need a solution. Help me. Thanks
Error:
Error while copying “MultiBoot.iso”.
There was an error copying the file into
smb://192.168.3.1/pcqlinux09/Final%20Live%20ISOs.
Show more details
Success
Read more
Driver epkowa (package iscan) gives excellent functionality [unsupported by the iscan-free package, requires DFSG non-free plugin in the iscan-proprietary-drivers package: iscan-plugin-gt-x750, overseas version of the GT-X750]
When I click on ok, after that I get the following error message:
Error:
YaST2 <2>
Error
The package iscan should be installed
but it contains proprietary binary-only i386-only software.
Therefore it is only available for i386 compatible architectures.
Some scanners are also supported by another driver.
If you really want to install iscan, you must do it manually.
Iscan is only available as 32-bit software.
On AMD...
Read more
Hello all,
If a program conks out, you normally found a view of a window open with some error message, along with a code number. Place the message and the number in your favorite Web search engine for a link to need an explanation, which may include a solution. This attempt causes more loss than hit, unfortunately. Gregory Braun's free Error Messages for Windows utility lists Windows error messages using their code numbers, but it's unable to help you find the source of the error. Hope I can get an advice from here. Thanks in advance.
Error:
Lookup
Specify an...
Read more
Hi experts
I am running this FTP only for LAN. When I am trying to download software from FTP (Linux, RHEL5) server I am getting the following error message:
FTP Folder Error
An error occurred coping the selected items from the FTP Server.
Details:
200 Switching to Binary mode.
227 Entering Passive Mode (10,1,1,1,40,75).
213 435847168
550 Failed to open file.
I need to solve it. What should I do?
Thanks
Read more
Cryptic error message of the day
Hi experts, I use Linux and I love to use it, but occasionally you must wonder just what was taking through the minds of a number of the developers.
For example when I (for all objectives and functions) tried to click on my DVD drive I got the following error message:
Error:
Unable to mount Avatar
Error mounting: mount: wrong fs type, bad option, Bad superblock on /dev/loop0, Missing codepage or helper program, or other error (could this be the IDE device where you in fact use ide-scsi so that sr0 or sda or...
Read more
Hi experts
The JavaScript console knows how to display the full log record or just warnings, messages and errors.
The error in following the figure shows that at aol.com, line 95 wants to access an indeterminate variable called is_ns70. By pressing on the link will start Mozilla's internal view source window by way of offending in line highlighted.
Error: is_ns70 is not defined
Source File: https://www.aol.com/; Line: 95
Read more
Hello experts,
In the Epson Smart Panel, I found this error message "an unnamed file was not found".
This application goes along with the Epson Perfection 2400 Photo scanner.
Need to solve this error message.
Thanks a lot.
Read more
Even while doing a maintenance clean i still keep getting dust marks on my prints.
Is there a way to prevent this.
Read more
