Archive
I am having some difficulty with creating links to files in Lotus Notes. I am able to create the links, but when the source file is changed it is not reflected in Notes. I am testing using Lotus Notes mail, and have been able to highlight a section of a file (e.g. Word document), and paste it into Notes (using Paste Special/Create link), and if I open the Word document and make a change within the section I highlighted, the change will be reflected in Notes.
If I make a change elsewhere in the document, the change is not reflected....
Read moreI have heard much about cloud computing. Everyone is talking about the advantages and benefits of cloud computing. What I want to know is that, are there any drawbacks using cloud computing? What about the security measures in cloud computing? Is it secure or not?
I am using Windows XP on my Intel motherboard.
A week ago it was working fine and I faced no issue.
But just two days ago when I turned it on it showed a lot of error messages after log on.
My whole screen is full of these errors.
I am using a good antivirus. I can’t understand the reasons for this error.
Please suggest a solution as I don’t want to reinstall windows.
Hi, currently I have a web server using normal HDD for data storage. But I want to setup a RAID for data storage so that my data is safe and secure. There are different RAID options available like RAID 0 and RAID 1. What is the difference between them? Is there any performance difference? Which is best suited for me?
I have two operating systems installed on my laptop. I am already using encryption on both of them. I know that WEP encryption works fine on XP and WPA works fine on Windows7. But a file encrypted in XP cannot be decrypted in Windows7. So please tell me is there any way to use WEP on Win 7 or WPA on XP?
I have two source codes, older and newer version. I can easily find trailing blanks in the older version but was unable to remove them. So please tell me that is there any way to remove trailing blanks in Unix based operating system. If yes how can I do it?
Read moreI am using a MAC book from one year almost. All I have heard about is that viruses cannot attack the MAC book. I want to know if it is right or not? If not, what is the best software to get rid of virus attack.
Read more
I am using Linux on my i5 laptop. I want to use fold on my machine but I don’t know much about it. So, I have some questions about folding in Linux.
What is the advantage of using Fold? How can I use fold Linux? Is there any software needed to use Fold?
Read moreWhile searching for a virus problem, I have come across a term called anti-rootkit. I don’t know much about it. Please explain: What is anti-rootkit?
I have AVG antivirus running on my computer (WINDOWS7). Should I install anti-rootkit also or not?
Why can't I get this to install?
I am at a loss for what to do.
Any advise on the matter would be appreciated.
Microsoft Office Access
The specification XML failed to validate against the schema. There is an error in the following line of the XML document: Whitespace is not allowed at this location.
OK
Error Installing.NET 1.1
(Error:1603) There was a problem installing “Microsoft .NET Framework 1.1”.
Note the error number and type this in a Web Browser
Hello. I have been unsuccessfully trying to installIntuit Quickbooks 2007 for the past week. After numerous failures, I relented...
Read more
