Archive
Hi! I just need to ask if there’s a way for me to change the postmaster accounts when you’re using a hosted environment; this has been concerning me for quite a while now.
You see, if a user sends a mail and then get a NDR, the Postmaster account will be generated from the master domain so that would have to be ABC.com and the hosted domain would be XYZ.com. I was wondering if there’s a way for the XYZ.com generate on its own.
I hope you can help me.
Thank you.
Read more
Hi, After installing Bitdefender successfully, I tried to set it up but then I got this error message.
It seemed the installation wasn’t successful, so I tried reinstalling but then again I got the same error message.
Any advice on how to fix the problem?
Please help ASAP since my PC’s not protected. See the error message below:
Setup
Setup detected a corruption setup will now terminate
Read more
hi,
I was installing BitDefender Internet Security version 10 from disk to my Win 7 PC then I got this error message.  Does this mean the version 10 is not compatible with Win 7?  Is there a workaround for this kind of problem?  I have searched the web and found nothing.  Please help me resolve the problem.
Screenshot of error message
Program Compatibility Assistant
Check online to see if solutions are available from the Microsoft website. If solutions are found, Windows will automatically display a website that lists steps you can take.
Read more
I just installed Bitdefender Internet Security version 10 on my PC with Win Vista and it was successful.  I then launched the software and it started updating.  However, the update failed (you can see the error message below) for unknown reason.  I tried searching the internet for resolutions but couldn’t find one.  I then turned to this forum and hoped that someone can help me resolve my problem.  Please help.
BidDefender Internet Security v10
Bitdefender Update process failed (unable to update or process cancelled).
Read more
Hello Experts,
My installation of Bitdefender to my PC failed.
You see, I got this error message, and since I wasn’t that techie, I didn’t know how to resolve it.
So I went to this forum and hoped that I would be provided with some answers.
Can you provide me a step by step procedure on how to solve the issue?
Thanks in advance.
My error message:
Installer Information
An error occurred during the installation of assembly component
{63E949F6-03BC-5C40-A01F-C88389A1E18E}.
HRESULT: 0x800736FD.
Read more
I was installing Norton Go back to my Win XP PC when this error message popped up in my screen (see below).
I searched the web but couldn’t find solution to the problem.  Then, I changed upon this forum and thought that experts would be able to help resolve the issue.  Please help me find or even better to tell me how to solve the problem.
Thanks in advance.
Norton Goback installer information
Error 25008: Norton Goback has detected unsupported partitions on disk #1.
This prevents Norton GoBack from protecting all of the partitions on this drive. Be sure to...
Read more
I tried moving a PDF document to another folder when I got this error message stating that access was denied (see screenshot below).  I wasn’t sure about the permission issue.  I own the laptop and I believe that I have full rights of all files and folders.
What do you think is the problem?  Any advice on what to do next?  Hope you can provide a simple solution that I can follow.  Thanks in advance.
Destination Folder Access Denied
You need permission to perform this action
Botany - Chinese Natural Medicines Materia Mcdi...
Type: Adobe Acrobat Document
Size 99,6 MB
Date modified:...
Read more
I was installing Norton Internet Security 2009 on my new laptop with Win 7.
The installation didn’t finish and I got this error message stating that NIS product required Windows XP or Windows Vista.
Did this mean that NIS 2009 I had wasn’t ready for Win 7?
What should I do next?
Please help.
This product requires Windows XP or Windows Vista. Setup will exit.
Read more
I was installing Alcohol 120% on my PC and it failed; ended prematurely.  I then I got this error message, see below.
I went to their forum and got a resolution but I was not that techie and so I couldn’t really follow.
Can anyone from this forum show me a step by step procedure on how to resolve the problem?
Thanks in advance.
Error 25002. Some driver has invalid name or conflicts with other file or services in the system.  Please choose other driver names or make sure you have rebooted after removal of software using same names.
Read more
We installed Timez Attack for our child in his PC and it was doing fine.  However, suddenly, an error message appeared (see screenshot below) and Timez Attack wouldn’t work properly.  We just recently installed an antivirus and we thought that it might be the cause but we couldn’t remove the antivirus software fearing the PC might get infected.  There were other messages the popped up but we didn’t know what to do.  Please help!
Error
There has been an error.
Error running C:TimezAttack.app/TimezAttack.exe : child killed: SIGABRT.
The application will exit now.
Read more
