Archive
I regularly use this component to pull my dll.
This third party component works fine for four months, but, recently, I encountered a problem with it.
First, I can’t find it anymore in the project toolbox. And secondly, it’s not pulling the OCX into the toolbox anymore.
Please help me with this problem.
Read moreI have to debug the dll code that I just generated. I have this VS2008 program with a function that sets the Start External Program, but the thing is that I need to use the VS2010 version.
However, I can’t find the same function in this version.
Read moreI do not know really exactly what happened with my Archos 605 WiFi. It suddenly stops.
I already tried resetting it but it got stuck on the opening screen with “Archos entertainment your way;” the HOD light also keeps on blinking red and the worst of it, it automatically turns off.
Is there any thing that I have to upgrade or change?
Read moreI do have some problems with my iCloud. Since I upgraded from MobileMe, I cannot view some notes on my calendar.
Lotus Notes won’t allow me to read my appointments through iPhone and iMac.
I can’t find any solution in the internet. Please help me find solution on this.
Read moreI want to start my SQL Query or DML Statement as a Web Service. I already search and read some guides but I wasn't able to followed it correctly. I have Oracle Call-In Web Service Installation or Database Web Service and I need to know how can I implement this with SQL Query. How to call Oracle SQL Query as a Web Service? Can anyone help me by sending resolutions with a much simpler terms?
Thank you.
Read more
I do Mac Book Pro whose screen is really small that’s why I wanted to use a bigger font size for my Xcode 3.2.6.
I did try changing the settings but nothing has happened. I also tried the command “+,” but I failed.
Are there any solutions you can give me? Please help.
Read more
I installed MIRC v7.19 to my Windows 7 OS.
It gives me a hard time connecting to any network, and it is compatible with my OS. I can’t use my command prompt since it always disconnects me.
I already checked the firewall settings and it’s working well. What else should I do?
Please help.
Read moreMy new computer has a Windows 7 OS.
When I play some videos on my Media player, the video suddenly and randomly stop.
I already did try something to fix this, like:
Checking the RAM timings are in order;
Removing fancy add-ons and extra applications from my desktop,
I also tried several settings for advance sleep functions,
I already uninstalling other antivirus and remain the Windows Defender, installation of SP1,
And updating my drivers for BIOS, Graphics card and Sound Drivers.
All these didn’t work, what else do I have to do in order to solve the problem?
Read moreUsing Virtex-5 FX70T (ICAP and PPC440), I write and read the frames, but SDK 11.5 shows an error message when I tried to execute the following functions:
XHwIcap_StorageBufferWrite and XHwIcap_StorageBufferRead.
What should I follow?
Do I have to use another function?
Read moreI just wanted to know if I can check on the JMS usage by using JMX while hibernating.
One more thing, I am spring’s Message Driven POJO but can I use it in a group.
I already arranged the configurations of JMS. Do I still need to do some rearrangements on JMS?
I need your suggestions guys.
Read more
