Archive
I have searched names of some people. Now, for some reason, I don't want to see their names to appear every time I will use the search bar/search people in Facebook.
How will i delete or clear the history of the person I searched? I have tried to clear the history browser, still their name appears in the search bar of Facebook.
Read moreHi,
I am trying to stay calm though I am facing a serious pc issue. I have been using a Lenovo G450 2949 B9Q laptop for over two months which is running on Windows XP. One of my uncles gave it to me as a birthday present. But it turns into daily struggle for me. From last week it starts to show a blue screen which says some kind of error occurred and beginning dump of physical memory.
A problem has been detected and windows has been shut down to prevent damage to your computer.
DRIVER_IRQL_NOT_LESS_OR_EQUAL
STOP: 0x0000000D1...
Read moreI have never faced such kind of wired problems.
I am running windows XP on my desktop pc and there four partitions on the hard disk.
In my F drive I can’t modify such as delete, rename or cut any files or data but can copy file to the other drive.
When I press the delete button to delete any files it’s showing an access denied message.
I am having no problems in the other partition. Is this a very bad sign for my hard disk?
Is it going to crash within a short period of time?
What to do?
Should I replace the hard disk?
Read moreHi,
I need your help guys to resolve this issue. I can’t add new files to my CD.
I have used Nero 9 to burn the CD with the multi-session open. After someday I tried to add some files to that CD but no way I can add the new files. It’s showing a message that if I burn the new files then it could damage the older files.
I don’t know what’s going on here. I have done the same process before for many times. Is this the fault of the CD or the write?
I don’t want to waste a new disk...
Read moreI have bought an Acer Aspire 4738Z recently. Every feature is working fine but experiencing a little yet annoying problem. I am using multiple USB devices and used to using the safely remove hardware icon in the taskbar to unplug any of the USB devices. But currently if I remove one of the devices then icon to remove hardware safely has disappeared magically.
I see no other options to remove the other devices. Now, how would I remove the remaining USB devices?
Can I just unplug the device, which could damage the device?
I don’t want to reboot every time to remove it.
Please give me...
Read moreI have some important data in my old Maxtor hard disk. Recently I have tried to transfer those data to another hard disk. But in the middle of the copying process suddenly it stops. After failing for couple of times, I tested the hard drive. The test result revealed that I had a bad sector or partition need to replace that hard drive before crushing the full system. But I need to retrieve those data before dumping the drive.
My question is:
- Is there any software available to repair the bad sector?
- Can I still use one of the good options of... Read more
Please help me to get back my hidden folders. My desktop PC was attacked by a spyware which was running on Windows XP, and I was able to remove the virus by installing the free version of Avast antivirus.
Every installed program is running well, but the folder option from tools menu has vanished.
Now I can’t access my hidden folders in drive C. The only way I know to get back the folder option is by reinstalling the operation system.
If I do reinstall the OS then I must loose the hidden folders.
So, I...
Read more
I have already damaged more then 10 blank CD guys and I need your help immediately. I have been using AsusDRW-24B1ST for last six months without facing any problems. But currently I am having serious problem with it. In the middle of the writing process, it vanishes automatically without showing any kind of message. I am using Nero 7 essentials to burn the CD. I thought it was corrupted and tried to burn after reinstalling the software. I have also tried by changing different burning options. But nothing can stop the error. What is the problem? Please share your...
Read moreI am a small businessman and using Gmail to send email to my business partner. I am not using it too much, only sending 10-15 mails per week. But these days I am getting too much spam mail, at least 10-20 emails per day which is very annoying. The emails contain adults substance too which I hate too much. I have to delete the junk emails daily.
Yesterday, I deleted some of my important emails accidently when I tried to delete those junk emails. How to stop those emails? Is there any software to stop the spam emails? Please I...
Read moreHi,
I am using a very old model monitor Samsung SyncMaster CDP 1751. It is my first monitor that I have bought with my own money. So I don’t to dump this monitor very easily. It was ok until last month.
But currently the monitor buttons stop working and I can’t change the brightness or sharpness.
When I press the button then a message appears on the window telling me that it is locked.
Control Lock
Unlocked
But I have never locked it.
There is also another option to unlock it, but I don’t know how to unlock it as no buttons...
Read more
