Archive
All my servers are installed in Windows Server 2008. I want to locate all the users where the “password never expires” is set in the active directory. Should I be using any command? If so, what are the following commands? How would I resolve this problem?
Read moreI updated my MindManager on my iPhone. I purchased it to create maps and I would like to import the files I have created. I backed them up and used the default extension which is .IMMAP. But the following files cannot be opened using the new version of MindManager. What should I do?
Read moreI am using Dropbox in my iPad when syncing photos and documents but I am having a problem renaming a Mind Map file. It keeps on crashing when I am trying to rename it on my iPad’s desktop. The file has the same name and the color label still exists. How would I resolve this issue?
Read moreHello everyone,
I am newbie in this. In one of PC magazines I have read about Rizone Security Restore program that can help you to restore your computer to the default security settings.
I got this program to fix problems after some virus problems. When I start application I got this one message.
Is this how it supposed to be or something is very wrong?
Any suggestion will be helpful.
Thank you
Quin
Rizone Security Restore 0.2.2.228
Use this for restoring your computer to the default security settings. Useful for when you get, ‘You don’t have permission to…blah, blah, blah’ type errors while...
Read moreHello,
I am a big fan of game smash Bros brawl and because of it I got dolphin r7144.
For some time it was all good, but today I got problems.
First game crashed and I got a blue screen and when I have turned PC again when I wanted to play the game I got error message.
What should I do?
I am a newbie in this. Windows 7, NVIDIA Geforce 8400 GS.
Cheers,
Recee
Warning
Trying to read from invalid SYSCONF
Read moreHi all,
I started using Linux OS and I am a new user of this OS. This may be something normal but I have to ask.
When I connect USB or iPod I got an error message. What should I do?
Thank you Rene
Error:
Cannot mount volume.
Error org.freedesktop.DBus.Error.AccessDenied.
Details
A security policy in place prevents this sender from sending this message to this recipient, see message bus configuration file (rejected message had interface "org.freedesktop.
Hal.Device.Volume” member" Mount" error name “(unset)” destination “org.freedesktop.Hal”)
My problem is pretty annoying and I don't know what to do.
In windows Explorer when I try to create a shortcut of any file I got an error message.
OS Windows Vista.
Can someone please help me with this?
Thank you,
Willow
Unable to create file
Unable to create the file ‘New Shortcut’
Not enough storage is available to complete this operation.
Read moreHey Guys,
I never had this kind of problem. In every Windows you get paint, and I use to have one in my system too.
This happened a few days ago, and I don’t know why. When I click on paint icon I get an error message.
OS Windows XP SP 2
Thanks,
Fran
Paint
Cannot find the file ‘paint’ (or one of its components). Make sure the path and filename are correct and that all required libraries are available.
Read moreHello,
For my notebook I got USB hard drive to collect files, back up etc…One time when I wanted to remove it click safely remove hardware I couldn't disconnect it. Because I couldn't remove it on the right way I disconnect it when computer was shut down.
From that time every time when I want to use USB had error message pop up.
Is there any chance to fix this?
OS Windows XP professional.
Tnx
Felicity
Run
q: refers to a location that is unavailable. It could be a hard drive on this computer, or on a network.
Check to make sure that the...
Read moreHi everyone,
A few days ago I got some PNG file that need to be changed. Recently on my Mac, OS X, I got installed Photoshop CS 5.5 installed. When I open the file and made some changes I got error message. After this I got problem with Photoshop. What should I do?
Tim
