Archive
I downloaded and installed Quick Media Converter (QMC) to my Win 7 PC, and it was successful.
However when I tried using it, I got this error message.
C:UsersSteveAppDataRoamingCocoonSoftwareQMCQMC.exe
The version of this file is not compatible with the version of Windows you’re running. Check your computer’s system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher.
It worked before with my Win Vista. Hope you can help me in getting rid of this problem.
Thanks in advance.
Read more
I got this error while playing with one of the TeknoGods mod in my game (see screenshot below).
DLLLoad.exe
File corrupted!. This application has been manipulated and maybe
It’s infected by a Virus or cracked. This file won’t work anymore.
I didn’t know how to get rid of this error, so I searched the internet, but couldn’t find any solution.
I chanced upon this forum hoping to get some answers.
Please help!
Read moreI was trying to access a remote server within the office when this error message popped up (see screenshot below).
The remote server has been paused or is in the process of being started
I just used the server I was accessing and wondered why this error happened.
I am just a new System Administrator and needs your expertise here.
Any advice on how to fix the problem?
Thanks in advance.
Read moreMy laptop gets very hot when I'm working on it.. do you know why?
Please give me a solution.
Thank you in advance
Read moreHi Gurus,
I was using Acronis Disk Director to partition my hard disk so that I can have multiple OS which I require for my program testing.
However, I got this error message while creating another partition for a new OS (see screenshot below).
Error
Acronis Disk Director Suite was not able to create the partition because there is no enough free space on the selected hard disk drive.
I checked my available disk space, and it turned out that I had enough for another partition.
I need your expertise here, gurus.
Please help.
Read moreI was using Professional Registry Doctor on my Win Vista PC when I received this invalid floating point error.
Invalid floating point operation.
I tried a reboot, but the same error message popped up.
I tried to look for solutions in the Internet, but couldn’t find one.
Any advice on how to fix the error?
Read moreRandomly I got this error message a while ago when I booted up my PC with Win Vista; please see screenshot of the error below.
Windows – Corrupt File
The file or directory System Volume Information is Corrupt and unreadable. Please run the Chkdsk utility.
I tried running the Chkdsk utility then after I rebooted, the same error message popped up again.
Any advice on how to get rid of this error?
Please help.
Read moreHello,
I was using ImgBurn in burning my files and backing them up to DVDs.
However, randomly I got this error message, see screenshot below.
ImgBurn
ConnectFilters (Source, Sample Grabber) Failed!
File Name: E:ROMsSaturnfatal fury 3Track02.ogg
Reason: No combination of intermediate filters could be found to make the connection.
Hint: You may need to install some additional DirectShow filters in order to support files of this type or the file might be corrupt.
I would really like to follow what was recommended but I wasn’t sure on which DirectShow filters to download.
Can you please help? Thanks.
Read moreI was using our Peachtree Accounting Software when I got this error message.
File system error number: 95 in file:
C:PEACHT~12010qcompanyBCSPERMISS.DAT; Click help for more information.
I was posting an entry when this happened. I tried posting again after seeing that it wasn’t posted but I got the same error message. I tried rebooting my PC and reposted the entry but nothing seemed to happen.
Help, please.
I need to finish my posting tasks.
Read more
I have been playing the SIMS 3 ever since I installed it together with its expansion World Ambitions. Then awhile ago, I got this error saying that it’s not a valid application.
D: program FilesElectronic ArtsThe Sims 3GameBinTS3W.exe is not a valid Win32 Application.
I tried rebooting and relaunching the game, but I got the same error. I didn’t know what to do next. Only option was to reinstall but it would take time and wasn’t sure if I could recover my data.
Please...
