Archive
I have a big table in Access containing some records. I need to export them to Oracle database running on the same machine.
The table has only 3 fields. Transaction ID, Customer, Salesman.
How do I send them to Oracle? Do I need to create a table there or something like that? I do not know Oracle.
Is there any simple way to do so? I played around Office 2007, export option but the closest I could get was to export to a text file. My friend said that you can also use this text file as an input in Oracle. But...
Read more
I recently built a Robotic Arm to move objects by human Control. The model was fine and effective. So my new partner who is an Image Processing expert wants to work as a team to expand it.
The problem is, he is on Linux. I don’t know much of Linux. So is there any way I can interface the controller with a PC running Linux, using C++?
The current design uses a small keypad, having 12 keys to control the arm(8) to move (4) to up/down/hold/leave . Each of them generating a 8 bit signal....
I have a user created in Oracle by the name "joseph". The initial table space was named as "tspjoseph" which used a data file named "josephtsp.dbf". Unfortunately, I set the size to 1GB which is not full filling the requirement. My whole software is up and the database is also filled with important data. Is there any way I can increase it, without affecting the current data?
I want to combine a couple of images, like placing them together and still undetectable. I want it to be realistic and at the same time easy to do. Can anyone help me?
Read moreHi,
I have been searching a Free Video Converter for so long, and unluckily I haven't found yet the perfect software that has no watermark and good features on it.
Here's my journey in searching for the kind of software that I'm looking for:
- I've spotted a software which has watermark too, but the thing is it is only for a 10 days free trial. And what I'm looking for is that a full free version on it.
- I've tried Xilisoft, but it loses a quality from the original video, such as the delaying for the dialog.
- I found this freeware with a very... Read more
I am having some troubles with the USB ports on my Desktop PC. Some days ago, while I used to using a flash drive on that ports, it was not working properly. After restarting the operating system, it began to work. I faced this problem for several times and I used to solve this problem by restarting the pc. But this time I have got a serious problem that these ports are not working anymore and this problem is not being solved by restarting the PC. I tried every possible solution to my PC. But I got failure.
To solve...
Read moreHi,
I am using Oracle to learn SQL. Just introductory. I downloaded the Oracle setup file from Oracle's homepage named - "oracleXE 10g". The software installed successfully, but I don't seem to find the user Scott, which was used in the class lecture. I missed the lecture so could not figure out if there was anything said which was not covered in the papers. I asked a partner who said it was a default user. Then why can't I access it? Do I need a configuration or something to be set up at the beginning? Or am I using the...
Read more
