Archive
Hi everyone,
I hope there are python gurus here. I am learning python, still new to the field. I would like to control the parallel port. It was quite easy controlling the parallel port using MS QBasic. It’s a challenge to do it using python. I am having a difficult time learning python, but with time i can do better. Recently i found an application called pyparallel. I installed it successfully and later tried it out.
It suggested testing with, >>>import parallel >>>p = parallel.Parallel() #opens lpt1 >>>p.setData(0x55) I tried this out. The import parallel worked well but the p {parallel.Parallel()}...
Read moreHi there by!
Hi, today I tried to connect to the internet through my landline network and found that the network is connected but I am not able to view any websites. I tried checking the IP address. I found that to be correct and I also tried to confirm all the usernames and passwords that I use to connect to the internet and found that was also fine.
I am totally unaware on what to do next. Anybody up there to help me.
Read moreMy Acer laptop has installed Vista 32-Bit Home Edition but it is not booting. It shows command prompt in the start which ask me to press F8.
After pressing F8 it directed to the Safe Mode option.
Any technical help please?
I was in the process of installing the Windows XP Pro32 onto my PC with 500 GB hard drive, but I realized that Win 7 is more fascinating.
And so, I stopped the installation process of Windows XP Pro 32, restarted the PC and proceeded in installing the Win 7.
During the installation process, the PC rebooted, and this error message had occurred “Windows could not start because of a computer disk hardware configuration problem.” I asked my friend who has knowledge on computer configurations to fix the concern but desperately, he was not able to solve the issue.
"Windows...
While I was in a middle of printing 30 pages of documents, my printer suddenly stops printing and there is no error showing on the screen. This printer has a built in scanner and copier.
After clicking the print tab on Microsoft word 2007, I can see the printer icon in my system tray at the bottom of my desktop, if I click the icon, the printer box will open showing me the status of what I am printing, like if it's already printing or Canceled.
I waited for about one minute to make it work, but...
Hi all,
Every time I boot my PC, I always get this error; “Windows could not start because the following file is missing or corrupt:
I tried to fix this problem with an emergency System Repair Disk but all of my attempts failed. I also tried booting while holding F8, and F7 keys but it all failed. The system restored to an earlier point but it could not be accomplished either. I tried to use the recovery console to copy my files across and this was the pop up error message,...
Read moreHow to fix Windows XP error message?
Hi, I am looking to purchase a new laptop from Dell for my daughter, who is in school. Since I am not aware of technical specifications, I am getting confused with the specifications.
Let me explain you the exact application, on which the laptop is going to be used. As I said she may use for her school homework’s, browsing may be and surely for playing games. So please suggest me a suitable one for all this applications .
Would be very much thankful.
Read moreWhen I was studying 8 years ago, we attended a seminar about computer hardwares.
I remember what the speaker told us, he said creating partitions are one of the simplest ways to safety your important files and also for much better arrangement of the files. For example putting all together the very important files inside the Partition A, then all music and videos will be placed at Partition B and lastly the other files in the Partition C.
Now, my question is this: Since it was 8 years ago, I don't remember the steps on how to make partitions.
I need someone to guide me on how to create partitions. And I want to...
Read more
