No of visitors who read this post:
149
Category:
Internet/Email Software
Type:
Question
Author:
Cabrera.sergio88
Yahoo messenger error: While trying to copy the messages which my friends sent to me on instant messenger it won’t allow me and a window just appears and says: “file:///C:/Program%20Files/Yahoo!/Messenge...do you want to continue running scripts on this page?” Nothing happened after pressing the “yes” and after that I pressed no and, as usual, nothing happened.
How can I solve this? Please help me. Thanks in advance.
After reading the whole situation above, it seems that there are some components missing from your windows. You just need to update these components. In fact you have to update your windows. The windows update will fix every problem. Try to keep your windows update because it’s automatically updating the components which are necessary for the windows. To update windows follow these steps:
Go to start and open Control panel.
Here find the "Update windows". Once find open it and update your windows as per instructions.
Note: Make sure that internet is working fine.
Hope this will help you to get rid of this error.
Thanks
