Update failed Samsung Update for Windows Phone
UPDATE ERROR appears when I want to update my Windows Phone. Now I really want to update my Phone because my phone is full with errors and crashes. Can anyone help me to update my Windows Phone properly ? If you have some time please tell me more about this error code…
Thanks !
Windows Phone
UPDATE ERROR
Update failed: Samsung Update for Windows Phone
We weren’t able to update your phone. Please try again. After updating, you might need to manually re-sync your pictures and other media.
We couldn’t create a backup of your phone.
To see if there’s more information about this error, click.
ERROR CODE
801812DD
Answered By 590495 points N/A #183743
Close the application and restart your computer. Connect your phone to the computer using the USB cable then start the Windows Phone software. Try updating the handset again. If there is an error again, check your connection. If you are using a cabled internet, check the network cable at the back of your CPU. See if it’s connected properly.
Disconnect the network cable from the port and then connect it again. Next, open any website on your web browser to verify your connection. In case you have a slow connection or your connection drops once in a while, try the update some other time. You won’t get a successful download in that kind of connection.
If you still can’t do the update, I think the problem is with the update that Microsoft provides. According to online forum reports, Samsung handsets that run on Windows Phone 7 are still unable to update. Microsoft is already looking at the issue because of numerous complaints they received.
