This error message window occurs when you run VBScript i.e, (.vbs) file. Considering my schedule, I usually deal in making Log-on scripts. Please see below for the screenshot and kindly advise for the solution. Thank you.
Error:
Windows Script Host
Script: E:\scripts\MapNetworkDrive\RemoveNetworkDrive
Line: 12
Char: 1
Error: This network connection does not exist.
Code: 800708CA
Source: WSHNetwork. RemoveNetworkDrive
Please follow the process here I discussed. It's nothing so exceptional to facing the problem like you have.
Here I discuss the solution step by step,
1. At first Go to Start menu to Run and type Regedit
2. Now you have to find out the given below key-
3. On the right hand pane, must have find Userinit.
4. Now put a double click in it so that it can edit its value.
Its value probably something like this (It will be depend upon your Windows Installation Directory):
c:windowssystem32userinit.exe
5. Remove the entry which load wscript.exe(c:windowssystem32wscript.exe) .
6. Now restart your pc.
For more better releif you also can visit here: Windows Script Host Error
