How database table called “service group” disappeared
I want to know how the database table called “servicesgroups” disappeared from the SQL Server database. It can select, delete and update without having a “drop table” statements. I also use ASP.NET application. The sites are installed with SQL 2005 express, Standard or Enterprise on a Windows Server 2008 OS.
Best Answer by SARA U
Answered By 10 points N/A #109164
Roland Guadalupe
Look there cannot be an issue that a particular table or record disappears automatically.
Either it will be a complete data corruption in the SQL, which can be checked by running the command
DBCC CHECKDB, and I am sure you will find NO errors,
OR, it is a deliberate delete of a table by some user.
A point to note, if you want to tweak your SQL tables and queries, I suggest you should visit this site
https://dzone.com/articles/how-to-optimize-mysql-queries-for-speed-and-perfor
SARA
Answered By 0 points N/A #109167
You can get you data recovered manually. In order to track the record of the process that is causing troubles and might hiding your database, you can use the log file managed by SQL server using SQL command
SELECT *
FROM fn_trace_gettable
(‘C:Program FilesMicrosoft SQL ServerMSSQL.1MSSQLLOGlog_19.trc’ , default).
This will provide you when and who dropped the database.
