No of visitors who read this post: 231
Category: Exchange Server
Type: Question
No votes yet
Hi experts,
I was trying to accumulate a Public Folder Database on Exchange Server 2007 but I keep getting this error message:
How can I debug this error? Any suggestion would be very much appreciated. Thanks!
Error:
Failed to mount database
'Public Folder Database' Public Folder Database Error: Exchange is unable to mount the database that you specified. Specified database: X2007SRV\Second Storage Group\Public Folder Database; Error code: MapiExceptionAD PropertyError: Unable to mount database. (hr=0x8004005, ec=2418)
Comment viewing options
Microsoft allows a hotfix resolution for this trouble. Hotfixes are little platforms that when established work to take away a peculiar trouble. You are able to explore for a hotfix on Microsoft affirm website. Afterwards downloading and establishing the hotfix resolution, run ISINTEG and ESEUTIL tool on interchange database. ESEUTIL is accustomed defragment interchange database, check unity and amend any harm. ISINTEG can scan data store and fix faults. Whenever interchange database gets seriously battered, ESEUTIL or ISINTEG cannot resolve the trouble. You've to apply an interchange host retrieval tool to repair the EDB data file. Whenever the above resolution does not clear your trouble, you can adjudicate Exchange Server retrieval software.
