No of visitors who read this post:
780
Category:
Mobile Hardware
Type:
Question
Author:
Renato Diggs
My Android phone is a hotspot generator. How can I keep others from using my phone as a hotspot- is there any shield software I can install? Also, is it possible for me to browse the internet using my own phone as a wifi generator? How can I do this? Thanks.
To use your phone as Wi-Fi generator, you need to use software. You can use scannify for this purpose. It will help you to manage your Wi-Fi network. You can also use this software for file sharing between PC & phone via Wi-Fi. For this purpose, Your PC needs to have “Connectify” software. Scannify application is available in Android Apps. It’s free. Just go to Android apps & search for “Scannify” You can also download it from this site www.connectify.me Try this. If you want to use its pro feature, then you need to buy this. Lite features are free
