Which Android Platform and Java SDK will work for beginner?
I want to start make Android application or games. Which Java SDK would be good (work) for my OS (Win 7 64 bit)?
Which Android Platform / Engine will work easily for beginner? There are too many choices.
Please let me know that one or two will work for me.
Thank you.
Best Answer by kristofferchua
Answered By 0 points N/A #161615
Try to start with android 3.0 cause the 3.1 or 3.2 will cater only few for now i think. Then download then download your ADT, it its a plugin for the eclipse IDE that designed to give you a powerful, integrated environment to build android apps.
I hope i answered your question, tell me if you have other question to this topic, maybe i can be of help.
Thanks
Answered By 10 points N/A #161617
Its look like you are trying to build java based game first thing to note is that what type of game you want to develop if it’s a big project then you need to check your requirements. You can download latest java SDK for this purpose form the java website.
Smith Thompson
