What Does Error Code 52230 Wii Mean And How To Resolve It.
My Wii is unable to connect to the internet from my wireless router. Whenever I try to connect my Wii it shows theĀ error code 52230 wii. Can anyone help to solve this issue? Thanks in advance.
Answered By 20 points N/A #304306
Hello, the error code 52230 wiiĀ is because of your Nintendo Wii is unable to secure wireless connection between the Wii and internet. Try the following methods to solve this error.
Make sure that your internet connection is compatible withthe Nintendo Wii. If it is accordant, then there might be a problem with firewall settings, go to the router settings then click on WAN setup and disable the SPI firewall.
The changing of routers channel may also help with can be done in wireless settings of your device. Place the Wii near the router for strong signals and restart the router.
Answered By 590495 points N/A #328209
If you encounter error code ā€œ52230ā€ when playing with Nintendo Wii, it indicates that the console was able to connect to the network but it can’t connect to the Nintendo servers. This problem may also indicate a problem with your internet connection. Note: Nintendo Wii does not support guest networks or publicly provided networks that will require a user to sign in or accept a terms of service.
Try troubleshooting your connection and verify that your internet connection is working. Try restarting the Wi-Fi router to troubleshoot your connection. If the router has a power button, press it to turn it off then unplug the router from the power for about twenty (20) seconds. Press any button on the router to discharge any leftover power or to power cycle.
After this, plug the router back to the power and turn it on. When the router is ready, open your web browser and visit a website then try clicking some links. Verify that your internet connection is working. If the problem continues, try changing your DNS server addresses. On your console menu, select the circle icon on the bottom left corner.
Next, select ā€œWii settingsā€ then move over to the second screen using the arrow button then go to ā€œInternet,ā€ ā€œConnection Settingsā€ then select the connection file you wish to edit. After this, select ā€œChange Settingsā€ then press the arrow button on the right three times or until you see ā€œAuto Obtain DNS.ā€ Here, select ā€œNoā€ then go to ā€œAdvanced Settings.ā€
Next, select ā€œPrimary DNSā€ then enter the following IP address and then select ā€œOKā€:
8.8.8.8
When you are finished, select ā€œSecondary DNSā€ then enter the following IP address and then select ā€œOKā€:
8.8.4.4
When you are finished, select ā€œConfirm,ā€ ā€œSave,ā€ and then ā€œOKā€ to test the connection.
