Warning Error java TM Update bin awt .dll
Hello tech savvy,
The system upgrade went successful without any major issues. I was literally happy but it does not last long. I tried to update the existing software in the system. While I am doing that, I came across this error message with java. It says some dll file is not found and no update done. But I did that update still I get this error. Where I’m going wrong? Please help. Thanks.
Java(TM) Update
Bin awt.dll: Old File not found. However, a file of the same name was found. No update done since file contents do not match.
