Upgrade MS-Office for Mac 2008 to 2011
I am using Microsoft Office 2008 for Mac for the longest time. Last October 2010, Microsoft Office for Mac 2011 has been released. I want to know now, if I will upgrade my current version of Office for Mac to 2011, what steps do I need to follow? Do I need to uninstall the previous version before installing MS-Office for Mac 2011? Can someone please provide a step-by-step procedure on how to successfully do that? Thanks.
Best Answer by Cathrine Due
Answered By 0 points N/A #117661
You can use office 2011 in your Mac
Still upgrade pricing isn’t available from an earlier version of Office 2008 for Mac.
You can buy a fully licensed version of Office 2011 for your Mac. Then install it on your pc.
Answered By 0 points N/A #117662
All you have to do is as follows-
1. first you buy the new version MICROSOFT OFFICE software which is registered and also has a license key.
2. open your mac book and go to control to remove the previous version. if you want you can replace it but it has the possibility to show up error.
3. remove the previous version.
4. now install the new version. after completing installation input your license key and its ready to work.
thank you .
