The Sony pen drive does not show any file or folder
Hello, I am using a Sony pen drive couple of years, but last week, it’s does not show any file or folder. I was cleaned “Advanced Options – clean files” with the AVG antivirus software. I also check “properties” and no hidden files are there. How can I fix this problem? Thank You
