Solution To COOD 1199
I can play CDA files on my desktop. However, I cannot play similar CDA files on my laptop. I get an error code C00D1199. I tried to download the Microsoft Codec installation package on my laptop but could not, present a disadvantage related to the incompatibility with Media Player11. I would like I appreciate each solution for the current problem.
Answered By 0 points N/A #321351
This error has occurred because you are trying to run a file through a player that doesn’t support that format. You should be aware of the drivers and the format they support. Then only you will be able to fix this issue. Go to any of the websites of your choice to get to know the device driver you need to support the format of your file. For the CDA format, you need to have a music cd playback only then the file will work in your laptop.
