My Wlsetup Web Exe Contained A Virus And Was Deleted
5 points
Posted on - 06/25/2019
My Device shows the following problem “Wlsetup-web.exe not found” when I try starting a *.exe file. What should I do to fix this?
The problem occurs because the system might delete the file WIsetup-web.exe detecting virus.
To use System Restore:
1. Open the “system restore” by searching through the start menu.
2. Choose a restore point. And follow the steps in the wizard.
3. Restore your computer to a previous point.
4. If the problem continues, then search for Windows Updates.
5. Open the “Windows update” by searching it in the start menu.
6. Install the updates by clicking the Install Updates button.
