How to restore my Active Desktop
I usually had a wall paper image as my desktop background. However, after I had encountered an error in the internet explore when I was browsing the internet which had caused me to forcibly shutdown/reboot my computer, I had noticed that my desktop background was turned to white with “Active Desktop Recovery” caption and a button which says “Restore my Active Desktop”. I tried to click the button, but a message window which will prompt you to “Run” or “Not to Run” a certain script will appear. I had tried both options, but still no to avail.
I tried to normally shutdown as well as restarted my computer but still the “Active Desktop Recovery” background exists. My first impression was that, I was been hit by Trojan or Malware so I then double checked my patches and virus definition. However, they were all updated. I also tried to run Full-System Scan, but my anti-virus found no malicious software and abnormalities on my system.
Any tips and advices on this issue are highly appreciated. Thanks.
