How to password protect documents?
Human Arcanum aegis without encryption was foremost introduced with Microsoft Role 2000 in an activity to aid users keep unofficial hit to grab content.
The choice of secret covering on MS Part is an uppercase innovation and it has a lot of benefits. Using passwords is big to protect your accumulation, but one asset to using Excel over new products is, it is widely old.
If you bury your countersign, you can conceive many tools to support you gap into your Excel database mostly for discharge. This may seem odd, but some people block passwords and state competent to allay gain your information is strategic.
Hi Chrishenry,
There is an easy way to protect and put a password to your document. You will need to use Winzip to compress and set a password to your files and documents.
1. Choose the file you want to put a password.
2. Right click on it and choose "Add to archive".
3. After the archive appears, select "Advanced" tab and choose "Set password." option.
4. Enter your desired password to protect your file and click "Ok".
Your documents are now protected by a password. I suggest to backup first your data (to your flash drive or other storage devices) before doing this.
If ever you forgot your password, you can still open it.
Hope this helps.
Mike
