How exactly I can view music from the Apple Tv??
I love to stand by in Apple Tv when I have nothing to do :)) But I have some problems and questions need to be answer so I can viewed on it easily and comfortably.
My questions are this:
1. How exactly I can view music from the Apple Tv, or even from my iPad easily without hazzle?
Question 1: How can I view music from the Apple Tv, or even iPad?
2. Can I use the iPad to also view the music library, then select a song to be played through the AppleTV, similar to the AirFoil iPad app?
3. Will eventually be running iTunes server (if this all works out) from a Windows Home Server.
4. Do I need to modify my AppleTV to get this functionality?
That are my four questions that needed to be answer by you guys. thanks
