Devenv.exe – Unable To Locate Component
I am running into an issue from the past few months. Reinstallation of the application helps me to get rid of the error messages. But I do not want to do that each and every time, I receive the error message.
I have Microsoft Visual Studio 2008 with SP 1 installed on my Windows Vista machine. I was able to work without any issues for 2 months, but all of a sudden when I am working on the application, it just crashes with the following error message.
devenv.exe – Unable To Locate Component
This application has failed to start because MSVCR90.dll was not found.
Re-installing the application may fix this problem.
The only solution out would be to reinstall in order to get it working. Is there any other way to go around this error message?
