CompanionLink MFC Application has encountered a problem: How to Resolve?
My situation is that I am encountering this message “CompanionLink MFC Application has encountered a problem and needs to close. We are sorry for the inconvenience”.
What can I do to remove or solve the said error message?
I attached the image below for further understanding of my problem.
I would be grateful for someone who can help me in this.
Error:
CompanionlLink MFC Application has encountered a problem and needs to close.
W are sorry for the inconvenience. If you where in the middle of something,the information you where working on might be lost.
Please tell Microsoft about this problem.
We have created an error report that you can send to us. We will treat this report as confidential and anonymous.
To see what data this error report contains,click here
Best Answer by Charle Faru
Answered By 0 points N/A #145020
Brayan Leonfried,
This error is caused due to invalid entries in windows registry, low disk space, some hardware in use by system is incompatible, system files are deleted by mistake or due to malicious application like Trojan, virus, etc., the companionlink.exe process running on the system is either damaged or repaired. This can be solved in various ways.
One is by running Companionlink.exe Error Fix Tool which can be downloaded from net. Download the tool, install, launch and click on Repair to get the issue fixed once the scan is completed.
Secondly, open the task manager >> Processes tab, and check for any process that is covering 100% of CPU usage and kill it.
Another way is to find out if any program is not completely installed, remove the program or reinstall.
– Charle Faru
Answered By 5 points N/A #195941
This could happen because of an error at the installation. Try to uninstall it and install it again. If the problem remains perhaps the problem is the.Net optimization Centre. So, click "start", "run" and write cmd and then "Ok". Then type cd and enter. After that type cd Windows/ Microsoft.Net/ Framework/ dotNetVersion and enter. I am sure that this process will solve your problem.
