Cannot insert a capture in OneNote
Hello. I have MS OneNote 2007 installed on my Windows Vista PC. I added it to my tool box and then try to run it but I got an error when using the "Insert at Cursor" option while inserting capture. The error is:
An Error Has Occurred
The OneNote 2007 accessory could not continue because of an error. Please try again. If this error continues please consult support.
OK other options as it is all working correctly. I tried this on both my Windows XP and this computer that I am using right now with SnagIt 8.2.3 and MS OneNote 2007 version 12.0.4518.1014. How can I fix this? Please send me some help. Thanks.
