AutoDesk the requested operation cannot be performed
Hi there,
During the initiating phase of installing Infrastructure Design Suite Premium this error appeared and closed the install. I have the right and compatible installer and it should work. Any solution for this error ? Is there an error with the installer or with my PC ?
Thank you !
Autodesk Infrastructure Design Suite Premium 2014
The requested operation cannot be performed on a file with a user-mapped section open.
K:SetupReseval.msi
