Archive
I want to buy a nec dxe 12 key display handset. Can you please tell me the price and its features? And is it worth to buy the same?
Read moreHello, I am trying to connect a handset to the ip2at 12txd headset, but I can not find any connection to the handset. Is there an upgrade card for the handset itself that provides a connection? Can anyone help, since it makes no sense, if there is a button to turn the headset on and off, then there must be a physical connection?
Read moreI am facing an error while using my Netflix account that says Netflix error code w8106 103. I am using it on my windows 8 computer. How can I resolve this? Please help.
Read moreI was thinking to use DAMN NFO viewer but I don’t know how to work on that. However, I have gone through many tutorials but still confused about how to open and edit info files. Can you please help me in regards to the same?
Read moreWhen buying my phone, a general firmware version of 10.50 is included. The phone works well even under extreme conditions. When Nokia released the new version 11.00, they announced improved performance, improved usability, and updated application. Nokia strongly recommends updating the versions published on the phone. So I try and everything works fine. But there are two things I noticed about this version of 11.00. [1] Strange "temp" folders with the extension .tec and .arc are often automatically created on my memory card. They are unreadable. [2] As soon as the total conversations reach more than 100, the "conversation update" remains...
Read moreHello people! A few days ago, my father had problems with his computer (built by me) when Norton stopped working. At that point, I could not do anything because I was very busy and told him I would watch what I'm doing now, but I'm lost because I want the problem. What happened was that Norton 360 did not open and caused the following error message: c: \ program files (x86) error \ engine64 \ 20.3.1.22 \ uistub.exe, unspecified. Can someone help to solve norton 360 uistub exe unspecified error?
I was trying to update parameter in my nqsconfig.ini file. Can you tell me how can I update the parameters for nqsconfig file in obiee 11g?
Read moreI want to setup obiee 11g ibots. Me being the end user trying to create the same but this is not working at all. How can I do the same please help?
Read moreHow can I create a linktopage in obiee 11g javascript. I am trying to do it but it is not working. How can I do the same?
Read moreI have the following warning: Error OBIEE 39008: The logical dimension table XXX contains a source that is not linked to a fact source. How can I solve this problem between my tables?
Read more
