Archive
Hi. What is the use of an Active Directory? Also, I have been trying to install active directory in windows server 2008 r2, but I make some mistake every time I try. What are the correct steps for installation?
Read moreOften some unwanted software adds a registry value for its existence to be maintained even if deleted and disables the registry editor for windows. What is the way around this?
Read more. Hi. What are active directory group policy objects? For example, if I want to keep track of changes between policies and after that, restore to a specific version of a policy then how can it be done? Please provide simple steps to do so if there are any.
Read moreHi. Active directory health check script provides what information? Also, which PowerShell script is used by active directory health check script and what information does it give? Thanks in advance.
Read moreHi. I have been trying to host my Active Directory in the cloud but every time I do that, I get an error saying “configuration not supported”. I have tried getting help from a lot of sources but to no good. Can you please tell me about the minimum requirements?
Read moreAs a new user of the Active Directory, I would like to know about the different management practices that are being followed as Active Directory groups best practices to ensure that no problems will surface on adhering them across the world?
Read moreHi. What is the use of active directory group membership report? What are the different groups which give us information about the use of this group membership report? How is it different from the existing exchange tools?
Read moreHi. I am using Windows 8, and I want to install users and computers for Active Directory for Windows 8 and other applications of Active Directory. What are the steps required for the installation of the same? Do these tools get installed by default?
Read moreHi. Can you please let me know about the requirements for the active directory for Mac os x and the steps to be followed so as to join my Mac OS X PC to the Active Directory? Please reply ASAP. It is urgent.
Read moreHi. I have been trying to install active directory install windows 7 but every time it is about to complete, it terminates abruptly. Can you please suggest me the proper steps of how to go about the installation. Thanks in advance.
Read more
