Archive
I have a GSM phone that I noticed that I cannot make a call in the 3G network compared to the 2G network without dropping. I thought the reverse would hold, could there be a problem with my phone ors its the network provider on the 3G service? I wanted to be able to utilize the 3G network
Read more
I have an stl file that I imported into keyshot from CAD and wanted to render this to 300 dpi image for clarity, what are the shortcut keys to use during this? Im familiar with belender rendering and wanted to add to this but just need to get started. What are the maximum rendering speeds on an i3 core machine?
Read more
I have an active http protocol for a secure address and wanted to be able to switch to the secure https for the same site on my intranet, how can I achieve this using PHP programming language? some devices cannot access this page and wanted to be able to rectify this.
Read more
I have a terminal in Linux mint and wanted to split channels so as to get the different packets to download at a slightly faster speed. How can I achieve this? I once saw someone do this through the establishment of multi channel communication in terminal. How many channels can be established for the downloads?
Read more
I have several clustered orphaned files that are in windows that I would like to collect together, the problem is that most of them are hidden and what more they are unrecognizable by the machine. Is there a disk utility software that can cluster these files together and delete the irrelevant files?
Read more
I have a local intranet that has several submasks and I have been running web servers without a problem due to the default gateway being fixed, however I was planing to install a print server and run this along the print server. Would I need to change my Ip address so that I can capture the default printer. I use a multi system that comprises both windows and Linux and the printer in supported in a Linux platform
Read more
I have a printer that has the what counter reading 100% and this has halted all operations at this machine, I have tried to unplug and the problem still persist. I checked this online and saw that the EPROM memory needs to be reset, I have no idea how to go about this and How long it will take. Is there a local software that I can use
Read more
I have blocked one of my print heads and wanted to clean the print head so that I can print in black. the problem is the accessibility of the print head, what solution is suitable for this job and how long before the head resumes normalcy? How can I prevent such a problem in the future?
Read more
I have a CDR and wanted to write some data but be able to add some files on it later. Is this possible and what would I need to make this happen? I would not like to waste space on the disks so I would like to utilize then entirely. How can I make up for the high write speeds for compatibility in other devices like the CD players in the cars?
Read more
I have an Alcatel OT 918 and having observed what my friend went through, I wanted to able to back up my boot files. My friends machine refused to boot and this prompted me to take precaution and make up my boot files. I have no idea how to do this for an android device. Where do I start and want do I need to make this happen?
Read more
