Archive
I broke my USB stick and have recently received it back from the data recovery company I had sent it to. They did format it into FAT32, but I cannot plug in the USB stick without it prompting me that it will erase all the memory if I make it a memory device. I need to know what to do in order to get the memory back onto my Xbox since I have the data on my laptop. Any suggestions?
Read more
I have a $300 sennheiser headset that I believe is much better than the Xbox one specific headsets that they recommend you to buy. The problem is that it has dual 3.5mm jacks that are audio in and audio out for the mic and headset. Will my headset work properly by picking up chat and stereo sounds if I buy their adapter with a single 3.5mm jack, and then use a dual 3.5mm converter to a single 3.5mm?
Read more
About a year ago, I purchased an Xbox 360- slim and since then have been playing many Rated M Games like halo Crysis3 and others. I recently got Titanicfall and every time I insert the disc, it loads the screen and comes to download named “Optimizing HD Content”. It then downloads for 15% and crash but the same time the Xbox makes a click. Help me please.
Read more
I have this version of OS that cannot be flashed for another (HP EVO T20) and I want to use it to put a client box for guests in the house so that nothing is to be put out of commission to be used. I just have a general idea of what to do but not completely sure. What would I have to do to make it a VM box? I also have an HP Proliant ML370 that I can use as a host for various other things. Thank you...
Read more
Am working on a Pc that has windows 8.1 Pro with Media Center, it’s recently upgraded from windows 8.1` Standard. After windows updates had been applied, I tried downloading a gotomeeting.com remote support tool to get a third party vendor in to install and license their software. While downloading with Internet Explorer 11, it hung at 18%. I tried with Firefox and it hung at 35%. I made sure there was no internet problem and I could not download from joinme.com either. My attempts to download the remote software from...
Read more
Hey, I will be attending college next year and am going to major in Computer Science or Software Engineering. Since I will be a boarding student, I would like to get a good laptop that will be suitable for me in college. My laptop budget is around $1500, what would be your recommendation? Thank you.
Read more
Hi guys, I need to buy a Blu Ray / DVD Player but am not sure of the type suitable for my needs. I want to be able to watch films on my laptop by using the Blu Ray / DVD Player and not just on the TV. Is there a Blu Ray / DVD Player that can be connected to a laptop? Your tips and advice on buying the Blu Ray / DVD Player will be appreciated.
Read more
I have a system with DATA on it from a friends’ business and it does not boot. I have tried to install new memory and put a new GPU but it still will not boot. Checking the PSU with a tester shows positive results. I have to completely drain the systems’ power when it boots and get one boot cycle before it shuts down. There was a power cut last week and I think it has something to do with it. If anyone can help, I would appreciate to be able to retrieve the DATA.
Read more
Hey, I have a windows 7 Pc on my work network and using PsExec I have a remote command prompt open of my friends machine in the office. I thought by just typing e.g. picture.jpg, it will open the image in their folder on their screen but it does not. I have even tried start “pic.jpg”, am sure am missing a simple cmdlet and I need help with the correct cmd that I can use to make it work.
Read more
I wish to enquire if True Crypt is still a secure option for Windows OS XP. I am curious to know if I have to decrypt my systems and eventually updating my hardware soon, most importantly the Mobo, CPU, Heat Sink Fan, Memory and GPU. I would also like to know if True Crypt keeps a system stable when the PC is fully shut down and no root log other than being presented with the password screen to go past the presented screen.
Read more
