Archive
When I open a new tab in Google Chrome, I am directed here: chrome-internal://newtab/. I'm not sure why this is occurring or what, if anything, I can do to resolve it. I am looking for help on this, as it is just annoying but not bothersome. Any suggestions, or is this common and I just need to stick with it? Thank you.
Read more
Hello, when I put in a DVD and play, the audio doesn't sound right. I've tried different DVDs thinking there might be something wrong with the DVD itself, but it happens with all of my DVDs. I'm not sure what the issue is. Could it be an issue with my DVD player? Thanks.
Read more
I've cleared all cookies and removed my history, but for some reason I am still having issues with certain sites loading. Maybe it is something else, but I'm not sure what else I need to do in order to get the pages to load correctly. Any suggestions on what I may be able to do to remedy this? Thank you.
Read more
I've never had an issue with Chrome before but now it is slow and seems to slow down my entire system. I'm not sure if I just need to switch my browser or what at this point, but it is a shame because Chrome has been my browser of choice for some time. Thanks in advance for any help.
Read more
I use Google Chrome and often when moving to a new page, it shows up blank. I'm certain now that it isn't just the sites as this happens frequently. I can use a different browser but it seems like there should be something that I could do to resolve this. Is this a common issue with anything I can do to fix it? Thanks.
Read more
I just upgraded to Windows 7 but something doesn't look right. I'm not sure if I should remove it then reinstall it, or if there is something else I can do to make it look better. Suggestions on what to do before I would try to remove it first? Thank you.
Read more
Literally, the scene is that I have a decade old speaker of my grand's and I want to play some music on it to test the sound quality. To my astonishment when I try to connect it to the back of my CPU then I have a CPU with 3.5mm cable port and the speaker has a non removable RCA cable joined with it. What can I do now? Are there any RCA to 3.5mm converters in marker? f yes then please give me the link. Are there any other alternatives  beside buying a converter?
Read more
I have recently bought this Linksys N300 WiFi Router on $40. It is fairly good and it promises of speed of 20 Mbps. I am now extremely annoyed when I saw that my seed on speedtests.net was only around 0.80 Mbps. What can I do to make it in 20 Mbps? Actually, my friend and I had bought the router at the same time in the same price but he is enjoying the speed of 20 Mbps and I am having a hard time sticking with 1 Mbps. What is the problem's cause? Should I call technical help or should...
Read more
I would like to purchase a home security system. Is HIVE system is the best security system that is out in the market? Is there any other security system with the same feature that I can use? How much does it cost to purchase it? What are the best features of this sound and security system? What are the materials used in manufacturing it? Can connect it with my handheld devices? What are the basic requirements to install its software?
Read more
I'm trying to upgrade from Windows Vista to Windows 7 and I keep getting stuck. The process is hanging up and I have to keep resetting back to Vista.  I'm getting frustrated. Can anyone help with the process and what I need to do? Thank you.
Read more
