Archive
Hai all,
I am in process of running the update manager, in the middle I got an error message stating installation packages from sources that are not authenticated. This means I should not continue with update? But this error is appears again and again. I do continue with the update it will crash the system? Help me to solve this error.
Title: Requires installation of untrusted packages.
The action would require the installation of packages from sources that are not authenticated.
azureus transmission-common transmission-gtkvuze
Read moreHi trouble shooters,
I am damn sure there is lot of empty disk space, but still why I am getting this error. I even tried this Disk Cleanup as instructed in the error message, no luck error is there. Thinking about system properties, do I need to check anything in that? Please help me to delete the file. Your help is great.
Cannot delete 6620: There is not enough free disk space.
Delete one or more files to free disk space, and then try again.
To free space on this drive by deleting old or unnecessary files, click
Disk cleanup.
Read moreHello Ally,
I am getting this error in ProShow, when I am about to create MPEG 4 video file. For you information I am having lot of memory space and windows 7 Operating System 64 bit with 32 GB RAM. Is there any restriction to ProShow? Could I able to increase the memory space usage for ProShow? Please help. Your help is appreciated.
Low Memory
ProShow has run out of memory and must be closed.
As with most Windows applications, ProShow is limited to a certain amount of memory usage. With your current show, ProShow is hitting that limit....
Read moreHi Whiz,
Recently I upgraded my system from windows 7 34 bit to Windows XP 64 bit. Then when I start to install the BlueStacks, Installation failed with an error message. I have the graphics card and it is perfectly working with other programs. But here it cannot recognize the card, help me to out. Do I need to upgrade the graphics card drivers too? So I need to do them separately. Help needed badly. Thanks.
Title: Bluestacks installation failed
Blustacks currently doesn't recognize your graphic card. it is possible your graphic drivers may need to be updated....
Read moreHi friends,
This is kind of weird message, when I try open .exe in Ubuntu I am facing this error. I recently I updated the Ubuntu to latest version, this might be the problem? Do I need to change any properties in wine? Please help to resolve this problem. Thanks for your help.
The file ‘/home/ctest/Desktop/vlc-1.1.11-win32.exe’ is
not marked as executable. If this was downloaded or
copied from an untrusted source, it may be dangerous
to run. For more details, read about the executable bit.
Read moreHi,
When I am installing the Autodesk Inventor Professional 2014, I got stuck up with an error message. I am doing this installation in my personal system so I think I have got all the privileges. The error is almost towards the end, why it is not checking this system privileges while starting? Please help me to find the solution. Thanks.
Title: Service 'Autodesk Simulation Moldflow MITSI 2014 Job Manager' (mitsijm2014) failed to start.
Error 1920. Service 'Autodesk Simulation Moldflow MITSI 2014 Job Manager' (mitsijm2014) failed to start. Verify that you have sufficient privileges to start services.
Read moreHello friends,
I am literally fed up with this error message in Miro. It was a clean install no errors, may be problem with other application or operating system. I googled the problem found miracle happened to some. Don’t find any solution? Please help me to resolve this error and enrich me with ideas. Thanks.
Title: ValueError: not allowed to raise maximum limit
Miro Error
Miro Error
An unexpected error has occurred during execution of the main script
Read moreHowdy,
Got an error message in zoom player while I am trying to play a song. The error message states me that audio format is not supported. I played the .avi format in windows player it is playing there. Sometimes I am getting error when I try to close the player. Is anyone have experienced this problem, please share your ideas. Thanks for your help.
Title: Problems with .Ts files
An ERROR has occured!
Pin Connection Error:
[Zoom Player Audio Filter]. Output ---> [Envy24 Family Audio (WDM)].Audio Input pin (rendered)
Code: Cannot play back the audio stream: the audio format is...
Read moreHi all,
I am using Comodo dragon, when I try to update it to a latest version I got stuck up with this runtime error. I should not have the older version? Do I need to uninstall the old one? From that point, the procedure was stopped. Please help me resolve this error. Thanks in advance.
Title: Error updating Comodo Dragon ver 6.0.0.10
Runtime Error!
Program: C:Documents…
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application’s support team for more information.
The error message stated me that source file might be corrupted, so I cancelled the Savage XR installation and I started again from the beginning to re-install. But I am getting this error again in the same point of installation. How to fix the corrupted source file? Please guide to the solution. Thanks.
Title: An error occurred while trying to copy a file
G:Savage XPgamemodelspropstombstone_propswesternmercantile_posts.s2g
An error occurred while trying to copy a file:
The source file is corrupted.
Click Retry to try again, I gone to skip this file ( not recommender), or Abort to cancel installation.
Read more
