Archive
I am not able to connect to my IMAP mail server with Gmail because of an exceeding bandwidth limits error on my Mac. I am using Snow Leopard on my Mac. I tried verifying that everything on my Mac was configured correctly by contacting the Apple Support. I then tried creating a new Gmail account and still get this same error. Trying to unlock the captcha too didn’t work for me. I can log into Gmail using safari without any issues. I tried disabling IMAP settings in Gmail and then enabling it back again. I have check all my...
Read moreHi,
I recently upgraded to Autodesk Revit 2012 and when I attempted saving a family in Revit 2012, I get an error message stating that a file was not found and this is followed by "File not Saved". The complete error message is shown in the screenshot attached. I tried to find out what is causing this error and I was informed that this error is given when a parameter begins with a decimal. My project makes use of many dimensional parameters and some of these make use of fractions. So now will all those files containing fractions be discarded?...
Read moreHello Experts,
I am trying install AutoDesk Revit 2013 using the install now option provided in the downloads section of the site. The installation fails with a communication failure error as shown below. I tried disabling my firewall temporarily proceeded to install. Here again after a while I get this communication error. I tried to download the file using download now having installed the download manager prior to its download. I launch the installation and still this fails after a while. What might be preventing me from proceeding with the installation? Please can anyone suggest a remedy to this solution?...
Read moreHi All,
I face an issue with the files sent through Skype. These files would not open and give an error message that says the file cannot be accessed because it is being used by another process. I am not using any Bluetooth device with Skype, and I fail to understand what causes this error. All the same, I attempted to disable the Bluetooth devices from Device manager and then tried running Skype. Still I get this error. I tried to uninstall Skype and reinstalled it back again. Only to find this error come back again when attempting to open...
Read moreHello Everyone,
I encounter this registration failed error whenever I try to install MapSAR on a computer running ArcGIS 10.1. The complete error message is shown in the attached screenshot below. I tried installing several times and this error gets repeated always. Why am I getting this error when MapSAR is said to work with any license level of ArcGIS 10 for Desktop. I tried downloading a Microsoft patch esri.com/AG10systemrequirements for windows 7 machine. But this did not help me in any way. What else am I missing? Did anyone else face a similar problem? Can someone recommend a fix...
Read moreHello All,
I tried to perform an upgrade on Adobe Muse on my OS X 10.8.2 machine and got an error saying that there is problem with the installer. I tried upgrading a couple of times and abandoned it to try an installation from the scratch. Here again I face the same installation error. I tried downloading Muse from the Muse Page on Adobe and from the Application Manager. But both installations failed. I ensured that Muse is completely uninstalled by dragging Muse into trash from the Applications folder and then emptying trash. Then I attempted to download the installer...
Read moreHi friends,
Reading this error message got little confused. I updated my system with new Antivirus software that was pretty good. After some research find out this error might be because of incorrect permission on the registry key or its parent container. Any change in antivirus software can trigger this kind of error, not sure. Please help me to find the solution.
SolidWorks 2012 x64 Edition SP04
Error 1406. Could not write value SolidWorks Office Installed to key SOFTWARESolidWorksSolidWorks2012Setup. Verify that you have sufficient access to that key, or contact your support personnel.
Cancel Retry Ignore
Read moreHi Pro,
Something went wired when I am working with webOS Emulator, got a message and it stops there. Pro’s I am good in finding such typical errors, but still working on that. So I try by reinstalling this again and but no luck. Getting this error message again, I was installing this in my windows 7 operating system. Whether I need to change my Operating System? Could someone assist me?
Error Image
Words in the Error Image
Palm webOS Emulator
The object functionality is limited
code E_ACCESSDENIED (0×80070005), component Machine, interface IMachine, calleeIUnknown
Read moreHi Experts,
I am trying to create an administrative connection on ArcGIS Server 9.3 using ArcGIS Desktop version 10 and an error message is returned that says it is not possible to create administrative connection using older versions of ArcGIS Server. What should be done now? Is it necessary to upgrade the server or is there any other work around to fix this compatibility issue? I can forward publish from ArcGIS Desktop 9.2 to ArcGIS Server 9.3. Then why is backward compatibility being an issue? Did anyone else face this issue or is this a problem with my updated ArcGIS...
I have been trying to upgrade the software of my BB9900 and was unable to do so. I get this error show in the screenshot below when attempting to do so. I downloaded the Desktop Manager and deleted the ‘vendor.xml’ file. And then opening it gives me this ‘Cannot communicate with connected device error’. I tried the ‘Retry’ option and getting the same error displayed again, I tried to update. And I get a message that says no device software updates are available. Is it necessary to have active BlackBerry subscriptions to perform a software upgrade? I don’t...
Read more
